Good Morning Friend,
I understand that the spin cycle is extra loud in your Frigidaire washer, model# GLWS1233A. I also see that you have grease splattering inside the front and right side panels at the bottom of your appliance.
Certain amounts of clunking or gear sounds are normal in a heavy-duty washer.
If you are hearing any rattling or clanking sounds, there could either be foreign objects such as coins or it could be belt buckles or metal fasteners.
If you are hearing a squealing sound, your washer could be overloaded. Stop the cycle and reduce the load.
Thumping sounds usually means this is a heavy wash load. This is a usual sound, but if it continues, your washer could be out of balance. Stop the cycle and redistribute the wash load.
If you are receiving a vibrating sound, there are a couple of things that could be causing this.
1)Your washer is not resting firmly on the floor. Make sure your washer is resting firmly on the ground as well as level. You will want to make sure that it is level from front to back, side to side, as well as from corner to corner.
2)The wash load could be out of balance. Stop your washer and rearrange the wash load.
With you receiving grease splatters, depending on how much and how often, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your washer as well as determine where the grease is coming from. Hope this is helpful.
-Best Regards-
WP
