Motorola Mobility Whisper Bluetooth Headset Logo
G
Greg Sampier Posted on Nov 16, 2015
They hear me, i can't hear them
When I call, my earpiece sounds like it goes dead. When they answer, they can hear me but I can't hear them.
My IHIP True Wireless Sound Pods left side sound pod goes in and out of reception. it cuts out then back on like it is losing signal
1) remove both sound pods/Air pods.
2) turn both off and then on at the same time.
3) double tap on the right earpiece
4) wait until you hear Bluetooth connected (the left is going to turn off. Which will be connected to the right.)
5) go back to Bluetooth and select the right earpiece and test it out.
hope this helps
Whenever i make or receive calls i can not hear the other person through my phones earpiece i can only hear them if its on speaker phone how do i check if my earpiece is dead?.what to do?
It is the hardware, the earpiece, you answered the wuestion yourself.
When there is no sound thru the earpiece, try using the speake mode or a bluetooth, if both works, then it's the earpice that is damage. I have no idea what phone model you have, but it can be replace or fix.
Jan 09, 2015 • Cell Phones
Cant hear anything when I make a call
The phone may be in headset mode. If you can hear sounds through the headset but cannot hear sounds from the earpiece on the phone, it's in headset mode. Power down the phone and restart it. Otherwise no sound from the earpiece mean a bad earpiece.
Oct 07, 2013 • Cell Phones
I have no sound from the earpiece when ringing a number, although it does ring out OK. It rings and receives calls Ok but I cannot hear the caller, except by putting it to loudspeaker. In all other...
sir while you answering the call press the volume button to increace the sound [or] give to the nokia service center for replacing the new earpiece mic for getting better volume................
I CANT HEAR THE CLEAR VOICE OF RECEIVED CALLER
Hello there,
There are two ways on how you can hear the caller. One is through the earpiece and one is through the phone's speaker.
Are you able to hear the caller but just not clear or with static sound? If yes, then you have a problem with the earpiece of your phone. You can test this by putting it to a speaker phone. If you can hear the caller clearly then you should have your earpiece check. Usually this problem is caused when the earpiece is often moisted or get wet. Try blowing a canned air on the earpiece.
Please let me know how this goes. Thank you for using FIxYa.
Nov 22, 2010 • Cell Phones
When i get a call, and i answer the phone, i cannot hear the person, although they can hear me, i have to put the phone on loudspeaker for me to hear them, which i don't always want to do.
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
This happens when i answer the phone with or without handsfree and i cant hear the callers voice but they can hear me.
If the volume of your phone is at the maximum, and yet you cannot you hear while you are been called or when you call, the problem with your phone is the earpiece, since you have adjusted and try increase the volume, yet, same problem. The earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
Replace the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Aug 09, 2010 • Cell Phones
Cannot hear anything on receiving call bt able to hear with speaker on or on hand set......
you have to change your speaker (earpiece)
when you choose the loud speaker option,,
you will able to hear the voice,,why?because the sounds transfer from earpiece to buzzer..its same when you use headset..the sound from earpiece will transfer to headset speakers..in that case,,you need to replace your earpiece..100% your problem will be solve!!
2helpful
Cant hear people when they call
Yes you are very correct. Its a earpiece problem. I use to have a Sony Ericsson K750i and the earpiece is not loud at all, so when I changed the earpiece, it began to work perfectly again. So I'll support or advice that you change the earpiece.
Take care.
Can't hear out of speaker when in call but can hear ringtones.
It is an earpiece problem. The terminals might be soiled, oxidized or loose. You need to disassemble the phone, clean and lift the terminals to ensure good contact. Check also the continuity of earpiece using an ohmmeter. Resistance should only be between 20 to 30 ohms. Otherwise replace earpiece.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
