If your remote has a [CC] button, push it to turn the closed captioning/ subtitles on.
If there isn't a button on the remote, look through the TV's Settings Menu ( usually under Accessibility if your TV's Menu has that tab. )
If you can't find it, you may need to get yourself a cable box etc. With the feature.
With Roku and other streaming sticks you toggle the subtitles/ captioning on and off with the [*] button.
If you want to add subtitle to online movie permanently, you can check this article.
SOURCE: subtitles disappear below bottom of screen
Check to see, what format the television set that widescreen etc. this may be all that's wrong with your set. If the problem persists the vertical height needs to be adjusted. Most likely through the service menu, if units under warranty you can call Akai. For further structures.
SOURCE: Polaroid TLX-04244B Remote wont work
5 Digit code is 15231
3 Digit code is 494
Hope that helps, took me about 4 hours to get that figured out!
SOURCE: I turned the tv on and subtitles were there. I do
Some TVs have a cc button right on the remote that comes with the TV.
Good luck !
SOURCE: Trying to figure how to
If the TV has a menu use it.
If not try unplugging the TV and letting it sit for a while.
This may reset it to factory defaults.
SOURCE: how to get the subtitles
A remote controller is required to turn that function on. Try a one for all and programme that.
