3019, 3021
Try these codes . not sure it will work, The rca crkt76 is not designed to use with HT systems.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
Pavani Sharma, according to your explanation, there is two possibility of problem :1st hardware problem all keypad had a water damage that why it is not working you need to clean main board with alcohol and let it dry for 2 hours, if you don't know how to do it show some official repairer.2nd Software problem maybe your keypad is working properly without sim or with sim but is is freezing after some time. for this you need to do hard reset, for he hard rest first switch off device and then press and hold * 3 and green button and then power on wait until shows insert sim, if software problem persist then show some official repairer to fix for you.
Get the model number off of the trimmer and go to this website: www.searspartsdirect.com You will be able to look up a schematic for your trimmer which will help.
I don't know the meaning of the code directly, but I got around it by setting up MAC filtering on my router (you go into your router's settings, get your DSi's MAC address, which you can get if you go into the system information, and add it to your router.
there is a problem detected with in the srs system(air bag circuit) that you need to have the code pulled to know what set the light.while the light is on you have no air bag system working as the computer to this system shuts it down until the light is out.this needs to be checked and repaired for your safety and anyone that rides with you.your insurance company may not cover you if this is not fixed(possibly),every company is different.
If you know the risks, try this ONCE and ONLY ONCE and let us know if it works. You have only 3 to 5 tries and then it will be hard locked. After that you will need a cable thing-a-me-jiggy to unlock it. It will still work on your Network so no big loss.
#pw+314646531133130+7#
Remove sim first,power on the phone. After the phone boots up, press # Press * 3 times fast for (p) \ Press * 4 times fast for (w) IMPORTANT Press * 2 times fast for (+) / and the rest of the code---
IMPORTANT!! Verify code before pressing the last #. Pay attention. You only heve about two seconds.
Note:If nothing happens. Some Phones require that you to insert a non accepted sim. Before you do this, make sure the sim you use does NOT have a security PIN CODE. If it does, reset the security code to default 12345 with the original phone. Insert a non accepted SIM and turn it on. You will see "phone restricted", select the UNDO option,then enter the code in the restriction box and press ENTER.
"Phone restrictions off", it's unlocked. "Error code" wrong code.STOP tell me. "Not allowed" or "Can Not Undo Restriction" it's hard locked. Used up all your free tries!!
you will have to do some steps to fix this up
if you have a desktop system...
1. open your system...replug the hard drive connections.
2. you can see the battery on the motherboard...reseat it
3. rest your bios to factory defaults
4 after that initiate the format
plz specify the system model you have..it will help me in gioving you a better solution
