Question about Quinny Buzz 3 Stroller
Where can I go to get he hydraulic to work in the stroller,it doesnt seems to open up when I have folded it. Any idea, where I can also get the handle bar?
  • Quinny Master
  • 1,637 Answers
Hi - Please contact Quinny customer care team by using the Contact Us tab on the website for your enquiry to be sent to the customer care team able to assist you. Quinny urban strollers and buggies
Posted on Jun 05, 2017
4 Suggested Answers
Anonymous
SOURCE:
Liz Wanden
  • 419 Answers
SOURCE: how do i lock the stroller when closed/collapsed.
It will depend on which model you have. If you have the older version, then there will be a nylon strap (usually found around the bag at the back of the chassis) this strap has a black plastic snap lock on that will go around the handle bar when closed and keep it closed.
If you have the newer version, this will automatically lock shut via a grey plastic clip on the side of the chassis.
I hope this helps.
Posted on Nov 04, 2009
Anonymous
  • 274 Answers
SOURCE: Bar has snapped between handles on my quinny zapp.
yes you can from www.buggypitstop.co.uk
Posted on Dec 05, 2009
Lucy Grace
  • 4 Answers
SOURCE: I slammed my stroller handle bar in my trunk. It
Look at this website www.vintagepramfan.com and I am sure if you post a comment they will advise.
Posted on Jul 13, 2011
Graco alano not folding? the push and twist handle not turning?? so the stroller does not collapse or fold. how can i get it to fold. wife needs to travel back and i am not sure airline would allow her if...
Took a while but finally figured it out. Original thinking was that the problem is in the handle twist and release mechanism. The problem actually lies in the collar where the unit locks into place. If the stroller is in the open position it can't be fixed unless it's folded up. To open stroller without the twist handle -- locate both black spring loaded collars where it locks into place (approx outside where the seat and seat back meet). Manually pull both the collars up the shaft. The spring is tight and it may take an extra set of hands to get the right leverage. Once the unit is in the folded position -- flip the stroller upside down and blast WD-40 into the hole where the spring pins are and work the black collar up and down. The twist mechanism on the handle will now work. My daughter claims it didn't even work that good when the stroller was brand new and we saved the time and trouble of shipping the entire stroller and seat system back to Georgia just to let the Graco people decide what to do. Bottom line is that this mechanism design stinks from the get go. Hope this helps.
Oct 12, 2012 | Graco Alano Travel System Stroller -Greer
We can't get the stroller to fold correctly, it worked once but we cannot get it to fold again.
I can't get my First Years Wave stroller to fold close. I have handle positioned down along with back wheels. Then slide red button, pull on handle/lever thing, but it doesn't fold the legs down. HELP PLEASE!
May 18, 2011 | First Years The Wave Stroller Crimson...
How do i put the chassis up and down
Push in the little white button on the frame handle and pull the 2 buttons on either side of the handle - if the frame doesnt fold doew gently move the handle a bit untul you hear a click then should fold
Jun 18, 2010 | Bugaboo Frog - Black Stroller
Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
Apr 09, 2009 | Quinny Buzz Jogger
Hi, quinny zapp
Here is the US distributor of parts for all Quinny Strollers...
Dorel Juvenile Group USA
Canton Commerce Centre
45 Dan Road
Canton, Massachusetts, USA02021
(781) 364-3100
(800) 544-1108
Jan 12, 2009 | Quinny ZAPP Stroller
Icoo pico 3
press the button on the handle (that colapses the handle) then sharply push the handle down and you should find that it folds down :)
Nov 01, 2008 | Hauck ICoo Targo - Hounds Tooth Standard...
Opening from folded position
i also found this annoying, the tracker chassis is similar to the ip-op chassis, which you can find instructions for online.
however when the chassis is folded, you first have to adjust the handle, to do this you push in the round black buttons either side of the handle, make sure the handle is in a strait line with the rest of the chassis. also check that the front wheels are in NON steering mode by pushing in the red button on the left hand side of the chassis.
once this is ok, you go back to the handle and push in the red button in the middle of the handle that confusingly says fold, as you push the button in, twist the black fold casing downwards, put your foot on the bottom crossbar and pull the handle towrds you. the chassis should start unfolding keep pulling the handle and pushing the bottom cross bar with your foot until the chassis clicks and locks on both sides.
da dah!!!!! there you go. now wait till want to fold it again bloody thing is a nightmare without instructions.
Aug 28, 2008 | Bebecar Tracker City U319 Stroller
Folding the pliko matic
To fold the Pliko, first the both handles have to be pulled out. To do it, grab the plastic (1) which is just under the handle (with a little hook on it), and pull it upwards. Pull the whole handle upwards, so it gets out of the catch situated near the front wheel (2). Do the same with the other handle (maybe it is possible to do it with both at once - I'm not sure yet). And then lift the back handle (3) (between the rear wheels) up, folding the pushchair. To lock it folded, you have to use the same catches, which had to be released earlier, to hold the handles - but this time they catch the handles somewhere in the middle (4).
Aug 22, 2007 | Peg Perego A3 Newport Standard Stroller
Quinny Buzz 3 Stroller Logo
343 people viewed this question
Top Quinny Baby Gear Experts
ray gallant
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
