Question about Toshiba Televison & Video
I have 32hlv66 toshiba tv, it has a blinking light that blinks three time then pause back to blinking. Will not power on replace seine board and still have the same problem. What could it be.
    Top Expert:
  • Toshiba Master
  • 76,204 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Posted on Nov 20, 2015
6ya staff
SOURCE:
Anonymous
SOURCE: blue power light blinking 3 times
I am having the same problem, what was the solution to this problem? And how much did it cost to fix it?
Posted on Jun 15, 2009
Chi Chu
  • 8457 Answers
SOURCE: I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Posted on Aug 20, 2009
Anonymous
  • 4 Answers
SOURCE: How to bypass seine card? 50hpx95
Turn off set, unplug power. Remove back cover. On brown circuit board left of center, unplug connector PJ63A. Plug in power, but don't electrocute yourself! If you no longer get the continuously blinking red light, hit the power button. If it comes on, the SEINE module is bad and must be replaced.
Posted on Sep 04, 2009
Anonymous
SOURCE: Panasonic TH-42PZ700U Blinking Light Of Death
Panasonic sent a repairman out with the correct part for free, even though the unit was out of warranty. Call 800-524-1448 1 or 800-211-7262
Posted on Oct 06, 2009
Travis S
SOURCE: hitachi power light blinking
Does anyone know how to fix this very common Hitachi problem without paying a repair man? And if you did pay a repair man did they fix the problem, and how much was it? I absolutely LOVED this TV before this happened. :(
Posted on Aug 07, 2010
Why doesn't it turn on?
http://electro-medical.blogspot.com/
Dec 10, 2013 | Toshiba 42TL515U 42 in. 3D TV
My toshiba 42hl196 popped when I turned it on last month. 3 blinking lights. Brought to tv repair - they say it was the power supply and tried replacing the ICs with a kit - did not work. Said coul
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
If the fault is detected with SMPS [Power supply board],it will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 09, 2017 | Toshiba 42HL196 42 in. LCD HDTV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
TV will not turn on Yellow power ind. Light blinks three times...
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
50HP95 Toshiba Plasma TV No power but blinking power light
I had the same problem with my 50HP95 Toshiba Plasma TV. It would not turn on. I read online that if you unplug a connection on my TV and it turns on, it is a bad Seine board. I could not find this Seine board anywhere online. It was either out of stock or no longer available. The TV is just 5 year old. Why would they discontinue parts for it? Then I saw a video on You Tube where someone unplugged a connection in the back of his TV to fix problem. I decided to try it. I took the back off, unplugged a connection numbered PJ63A and the TV works again. So far so good. I downloaded the Service manual for this TV to find where PJ63A was.
I also called Toshiba Tech Dept. to find out if there was a chance I can cause further damage to my TV. They had no idea.
Mar 27, 2009 | Toshiba 50HP95 50 in. Plasma Television
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Dec 13, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
