Hi karwan , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? asking for what code????Hi karwan , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
toshiba lenscopier
what is this? google shows zero hits. must be a printer (Plus)
try telling, ful model numbers and names of TOSHiba thinnngs
Toshiba estudio 455
this>
If you want quick and reliable response of your query or issue that you have been facing in your Toshiba device you just directly connect with Toshiba Printer Support Number 1-800-243-0019 which provides you proper guidance regarding your problem and whoever takes your query will be an expert technician. So don't worry about your problem now , the support that you want is just a call away or visit :http://toshiba.printertechsupportnumbers.com/toshiba-printer-customer-support/
Segun El Ribbon de toshiba me dice que la tarjeta de SyS es igual de la toshiba E-455 a la de la E-855. El problema es como hago la transformacion de version 455 a 855 . Mi pregunta es como hago o cual es el procedimiento . Gracias
Sounds to me like your HDD has gone Tango Uniform. On a 452 I would find a 40GB HDD somewhere for cheap, slap it in and then follow the directions in the Service Manual (probably can find it by googling) You'll also need a copy of the latest firmware (SYSTEM 356 on that model). Good luck!
switch hold down 08 while holding 08 down swich on machine wait until test mode starts on the number pad put in 400 and press start input 0 and set switch off wait 30 seconds and swich if error code c440 is back you have to replace thermistors and thermofuse
