The main board will need replacement. Its very common issue where the set will freeze at the vizio kogo then eventually it wont turn the logo from orange to white so it can power up. Replacing the main board should solve the issue. You can get the replacement main board from www.tvcircuitboards.com
does the vizio logo light up orange ? If so and it doesnt turn white then the main board would be suspect. If the logo doesnt turn orange when its pluuged in then its the power board. You can get either board from www.tvrepairworld.com
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
