I was sure that I had added some tips but under my activity I see none. So I tried adding a tip and it gives an error select a category but there is no drop down category to select anywhere! So how do you add a tip? Who can fix this website. Viewing in iPad
Hi Jon,
The categories should appear in a dropdown as you begin typing. There are many categories, which is why they are not all listed at once. Start typing and you should see a dropdown appear.
Also note that when posting a tip it may be a short time before the tip will show since tips must be reviewed.
If you continue to have problems, please leave me a comment or feel free to contact the Fixya Support Team for more help with troubleshooting.
http://www.fixya.com/contact
Hope that helps!
Testimonial: "Arr yes I see it now that I type slowly in the section "my tip is about". Thanks. How long does it take before the tip is published, after being reviewed? And if the "my tip is about" doesn't match any of the fixed categories, is there a way to add a new one?"
The tip should be published pretty quickly I believe, although I guess it will depend on the queue but I would think no longer than a day. If you have a suggestion for a new category, please direct it to the Support team using the same linkhttps://www.fixya.com/contact - hope that helps!
Recently the “my tip is about” list is not appearing again, even if I type slowly. This is on ipad safari, if I use another browser it is ok. Perhaps a pop up blocker is stopping it. Its mighthy inconvenient. Can the web page be updated to make this easier?
What would be nice is some form of confirmation. I added a tip, and it seemed to vanish into the ether. I have since submitted the same tip 5 additional times before looking into this.
A few hours have passed, I will check to see if it was posted or declined. I may add content if it is accepted, because online the help forums are pretty terrible.
nearly 3 days have passed. My "Tip" was neither rejected, nor accepted. WTH? It just vanishes into the ether after all.
