Question about Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb
130BT Blower can't pull start cord.
Unit was running perfectly then stopped suddenly. Now unable to pull cord. Removed casing and starter cord and there is no issue with the starter cord. Tried turning the cylinder behind the starter cord but it is very difficult, even with a wrench? Any ideas.
  • Kent Rawlings
    Kent Rawlings Nov 23, 2015
    Figured it out.Small branch (2") got stuck in the fan part of the blower and was stopping it from
    spinning. Had to take it apart to find it. Works fine now. NO idea how the piece of wood got stuck in there!
    Sergeant:
  • 344 Answers
Can be a couple issues. The obvious is seized. The other is a broken jammed connecting rod. I would put some oil down the plug hole and let it sit overnight. Then after a day or so...try again with the wratchet. In both directions, forward then backward just to try and free it.
Posted on Nov 22, 2015
6ya staff
SOURCE:
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
My blower stops running and cord got stuck
Does it seem to be the cord holding the unit? Try to turn the blower in reverse. Disconnect the spark plug and use a screw driver to reverse the blower., If the starter pawls engaged for some reason and jammed the engine, this should free them. If not, there could be problems inside the engine.
Mar 10, 2015 | Poulan Pro 25cc 2-Cycle Gas Blower...
I just bought a Sears Craftsman snow blower,put gas and oil in it.Itried to pull the starter cord but it will not pull. I then tried the electric starter but it just grinded.Why won t it start?
Sounds like a serious flooding issue, perhaps due to having blower on its side, take out spark plug and place plastic bag over and try pulling over, be careful that it doesn't spark and ignite any fuel expelled out of cylinder.
if that is the case pull over several times blow off plug and try again, fuel might be trapped in muffler so be aware of spray, ignition.
If it doesn't pull over with the plug removed take it back as a valve might be sprung.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Mar 02, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
My 130bt blower stops reving after several minuets. Will start but not rev after running fine for 5-7 minuets?
Hi and welcome to FixYa. I am Kelly. The next time it does this... loosen the gas cap a lot momentarily for about 10 seconds then tghten it and attempt a restart. If if starts right away again the gas cap is bad. It is supposed to breathe via a rubber seal in the cap. There are 5 parts in the cap. If it can not breathe the gas tank goes into a vacuum as fuel drains and you will experience fuel starvation.
Also check inside the fuel tank for debris.
See this link http://www.jackssmallengines.com/help.cfm#Home
Click on
Husqvarna Power Equipment
Blowers
130BT (I used the 2001 - 2007) There is also a 2008-2010 choice
and then click on Fuel tank a.s.s.y
I suspect the problem is either going to the the fuel cap or the fuel filter.
Thanks for choosing FixYa,
Kelly
Nov 10, 2010 | Husqvarna 295cc Back Pack Blower HVH 130BT
How do I disassemble the housing to get to replace the starter rope?
Hi.
Disassembly procedure depends on the make and model. Please provide model info for the unit.
Thanks.
Sep 04, 2010 | Garden
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Unable to pull starter cord at all
pour some gas/oil mixture down sparkplug hole and let it soak and see if the rings are carbon blocked
Oct 04, 2009 | Electrical Supplies
Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb Logo
597 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
