I've followed the instructions in the manual but its not working.
SOURCE: Photos stuck on integral memory?
When viewing pictures, select the 'Menu' option. Scroll down and on the second page there's a 'copy' function that can either transfer photos from internal memory to a memory card or vice versa.
I didn't know this was possible until today, either. Handy!
SOURCE: Can't download/upload photos from camera's memory; how can I transfer to memory card?
pg 16 of your owners manual:
• Picture data recorded on the built-in
memory or a card can be copied from
the built-in memory to the card or vice
versa. (P90)
See page 90
heres a link to your om if you dont have it
http://service.us.panasonic.com/OPERMANPDF/DMCTZ1-MULTI.PDF
SOURCE: on screen it says memory card error please check
Make sure the cards are 2GB or less, 2GB is the largest the camera can support. If they are, you may need to format the cards to use with the camera. Press Menu/Set to display the PLAY mode menu and select the item to set. Select Format and confirm by select Yes. The owner's manual says to perform this procedure when you get MEMORY CARD ERROR.
SOURCE: Can I transfer internal memory photos on to the
Go into the menu and find "copy". You will have the option to copy the internal memory to the memory card.
SOURCE: How can I transfer photos from internal memory to
should have option for that in the menu,,,
