Drive rollers turn yet don't get paper.
The printer transmits boisterous, pounding clamors.
Printer lights are squinting.
The carriage get together, which holds the ink cartridges, slows down at the left half of the printer. A paper jam may have happened beforehand.
If you want to proper detail regarding hp printer then you can call on 1-888-924-2961 toll free number for hp printer support services.
Technical Support For HP Printer
Looks like your rollers and bearings have some wear and/or damage check it and replace if possible.Regards, Mike
SOURCE: Hp laser jet 1020 paper jam and not printing
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
SOURCE: paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
SOURCE: Why will the HP Laser Jet 1020 not print?
this is a usual problem with the early models of printers. if you go onto control panel and then printers for the properties then print test page. if this prints fine then you will have to use the add/remove programmes to remove printer software. then delete the printer and install again but not from disc as windows has a package which will do it for you. leave disc in drawer and dont run. just search for the drive whilst installing printer. if this doesnt solve your problem then use the software which you will have to install again. if this doesnt occur then take cartridges out and check if they are correct ones or compatibles as hp not too compatible friendly due to counters.
SOURCE: while i print a paperon my hp leaserjet 1020 printer i find black spots on paper
It sounds like the toner cartridge is leaking.
SOURCE: how i print a watermark picture in hp 1020 printer
To change the default settings for all future print jobs in Windows XP
1. In the Windows task bar, click Start, select Settings, and click Printers and Faxes.
2. Right-click the HP LaserJet 1020 printer icon.
3. Click Properties, or click Printing Preferences.
4. Change the settings, and click OK.
5. On the Effects tab, select the watermark you want to use.
NOTE Not all printer features are available from all drivers or operating systems. See the printer
properties (driver) online Help for information about availability of features for that driver.
