Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt Installation Tips: Side of belt with words faces away from drum
Style: Flat with ribs Installation Tips: Ribs face toward drum Diagram B Style: Flat with ribs Installation Tips: Ribs face toward drum Diagram C Style: Flat with ribs Installation Tips: Ribs face toward drum Diagram D Style: Flat with ribs Installation Tips: Ribs against drum Diagram E Style: Flat with ribs Installation Tips: Flat side of belt against drum Diagram F Style: Flat with ribs Installation Tips: Ribs against drum Diagram G Style: Flat belt Installation Tips: Side of belt with words faces away from drum Diagram H Style: Flat with ribs Installation Tips: Ribs against drum Diagram J Style: Flat with ribs Installation Tips: Ribs against drum Diagram K Style: Flat with ribs Installation Tips: Ribs against drum Diagram L Style: Flat with ribs Installation Tips: Ribs against drum Diagram M Style: Flat with ribs Installation Tips: Ribs against
stick the belt pulley in the holes closest to the motor. if you have a belt pulley like this. get the belt and hold it together so you have a loop at the end and run under the pulley so the pulley lifts up and put the belt on the motor shaft. the belt always goes under the pulley so you are lifting upwards
All models use this diagram:
If your dryer belt has ribs on one side you would think the ribs would go face down on the drum. try it with the ribs up and the smooth side down on the drum. If you can figure out the belt route and it doesn't look right due to the ribs then the cure for that is flip the belt over. Good Luck
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included. The important part is the routing around the motor and the tensioner pulley.
For Hotpoint Dryers 1970- 1990 standard capacity
1970- 1990 Large capacity
1990 – to present Style: Flat with ribs Installation Tips: Ribs against drum
For Kenmore models starting with 110 or C110 with a removable back use this:
For dryers starting with 110 or C110 with nonremovable back use:
For Dryer models starting with 417 use:
