Retail Supplies Logo
Melissa Haines Posted on Nov 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PEA is on the screen and no keys work - Retail Supplies
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Nov 26, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066274
Points
28436
Stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
1helpful
The register display Says PEA and does not do anything
TUrn you key to pgm and press subtotal then switch on the machine while depressing sub/total button. good luck
Applying thermal paste
pea size is the best ..... "Little is more"!!!!!
5helpful
2answers
Hi There my SAM4S is showing PEA on the screen. All the buttons are locked also. I have unplugged and it doesn't change anything? Can you help?
I have a SAM4s register. When it read "PEA" all I did was pull the receipt paper. It seemed to be jammed. Worked for me.
3helpful
How to fold kidco pea pod tent?
hi there.. Watch this video to help you in folding your Kidco Pea Pod tent. Hope this helps.
I am going to put pea-stone all over a sloping hill .. How do I stop the pebbles from all landing on the bottom in a pile?
That depends entirely on the pea gravel and the slope of the hill. Read the Wikipedia entry on "angle of repose". Pea gravel typically has an angle of repose of 45 degrees or less. If you hill is less steep than 40 degrees you will probably be OK. Otherwise, you would need some retaining walls to reduce this angle. (Probably not what you had in mind.) Best thing to do is go to the source of your pea gravel and measure the slope of the pile it's in. This will be the maximum angle of repose for that material. Compare this to your hillside. If the hillside is at least 5 degrees less steep, you should be OK, unless you will expect foot or vehicle traffic on the pea gravel - in which case you would need at least a 15 degree margin.
Jun 15, 2010 • Garden
PEA is the screen...All the are locked and even if i pull the plug out it still comes up.... How do i get rid of it??
hi. Sorry, I don't understand. Does the display only show 'PEA'? I have never had this. Please let me know the model number.
Mark
Top Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Retail Supply Expert? Answer questions, earn points and help others
