Version fran?aise pour cette page · AEG - Uscatoare de Rufe Manuale de utilizare ... 2,Lavatherm 310 A; Instruction Manual - Product Number Code:607625015.
I have some different sources. http://aeg-electrolux.manymanuals.com/ as a first option for user guides. You have to use search textbox or brand search. Enter your AEG Lavatherm protex plus and choose among other manuals.
If you open it up you should find the tech sheet on your dryer. It will explain how to put it diagnostic mode, then you can test the door switch and see if it's not the problem. My bet it's the belt.
refer to the manual that came with the safe it will have a master code included or instructions on how to reset the unlock code or you can contact a lock smith or the manufacturer and they will be able to assis
Do you have an error code displayed ? If so what is that. If not the either the door switch is faulty or the control board. More likely to be the door switch but, strange things do happen.Here is the door switch number 134813601. If you need help installing or more info let me know.
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
