This sounds like Handset #1 has lost its "registration" with
the base. De-registering & re-registering is often easy.
First, be sure the handset battery is well charged as a
weak battery will interfere with the registration process.
Then try this ( 'works for the D1680, D1481, & similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
within ~30 seconds the handset should display
a "Handset #" and be good to go.
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
