GE WDSR2080D Top Load Washer Logo
Carol Bark Posted on Nov 29, 2015
What is the capacity of washer GE WDSR2080G2WW?
WWRE5240D1WW. What is capacity in cubic feet?
On the GE appliance support site, they list a WWRE5240DWW washer with a 3.5 cubic foot capacity. There is also a WWRE5240DCC with the same capacity. Based on the parts list for various GE washers with similar model numbers, the WWRE5240D1WW is also a 3.5 cubic foot washer and is minimally different from the other washers.
I hope this helps.
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear
GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
1helpful
What is the capacity of the GE Profile WPRE6100G?
• King-size, 3.5-cu. ft. stainless steel basket makes room for more items, which
means less time doing laundry
How to repair drive belt on GE Profile washer
Contact the GE Washer div. and request a schematic of the machine. It will show you the detailed format for removing parts and construction teherafter.
Do I keep my old Kitchenaid extra capacity or keep the new GE GTWP1000
The GE has a capacity of 3.3 cubic feet. You did not list the model of the kitchenaid. Make sure the GE was stored correctly because if it might have lost oil or gotten brittle belts or gaskets. Also it might have frozen.
8helpful
I have a GE WPSR3100 washer...need to know the cubic feet capacity size?? please help
According to a spec sheet I have from GE when we bought it eleven years ago the capacity is 3.2 cu ft.
1helpful
2answers
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
1helpful
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
What is the load capacity for the GE WPSE4200AOWW Washing Machine?
not sure exzakley ive repaired thousands of washers though.just dont pack the clothes in it.God bless,tom
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
