I have an F09 fault code to which there is no remedy for. I have reset the power but still get the fault code. How can I reset the machine and clear the fault code ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
SOURCE: U2 fault code?
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
SOURCE: LE CODE
This problem started to occur for me about a week ago in about the same way as others have indicated, AND about 16 months beyond the expiration of the warranty. This CANNOT be a concidence. What a tick off! Also, the 800 number "help"line is a joke.At this point I am about ready to file a class action lawsuit, or at the least bad mouth this product to whomever, in or out of the media, will listen. Can I get an AMEN?
