Apple iPad 64 GB 3G Tablet PC Logo
A
Anonymous Posted on Nov 30, 2015
IPad will not charge even though battery and charge port both replaced.
I have an iPad 3 that has a power problem. It will not charge even though I'm using a good Apple OEM charger and data cable that I know works. I've tried replacing the battery and the charge port with known working replacement parts but that didn't help. However, if I install a charged battery, the iPad turns on and works just fine until the battery is drained. It simply will not charge. There is no liquid or any other visible damage to the iPad. What could be causing this problem?
Chen Pei
Level 2:
Sergeant:
Habit-Forming:
  • Apple Expert 109 Answers
  • Posted on Dec 13, 2016
Chen Pei
Apple Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
109
Questions
0
Helped
138664
Points
612
You can buy the corresponding ipad parts in this site, replace your damaged parts. Very simple, but also cost savings. IPad Air iPad Apple products YDT parts
Louis F Hoholek Jr
Level 3:
  • Master 1,140 Answers
  • Posted on Nov 30, 2015
Louis F Hoholek Jr
Master
Level 3:
Answers
1140
Questions
0
Helped
259009
Points
4510
Incorrect port part, Wrong polarity for wires connected to the port or poor connection of wires to the port.
Ipad air plug in will not charge. turn off the ipad and plug in ipad turns on but doesn't charge?
Apple support suggests several possibilities. The iPad may not be receiving sufficient power to charge it; some lower powered charging devices are lacking. The charger may not be Apple certified (as being adequate). Test an alternative charger. Or, the port may be dirty or damaged. Remove debris. Try another USB cable. Restart the device. Also, determine whether or not you have the latest ios operating system. If it still does not charge, contact Apple support for service.
For more detailed instructions: https://appletoolbox.com/ipad-air-charging-very-slowly-or-not-charging-fix/
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
1helpful
My i pad will not turn on
First steps: Make sure you're up to date
  1. Verify you have installed the latest version of iTunes.
  2. Verify that you are connecting iPad to your computer using a USB 2.0 port.
  3. Make sure your iPad software is up to date: With your iPad connected to your computer, click "Check for Update" in the Summary section of iTunes.
  4. Charge your battery: Using the USB power adapter that came with iPad, charge iPad for at least 20 minutes before further troubleshooting. If necessary, refer to "Charging the Battery"
Ipad will not start?!
There are a few things to try. 1) Press the power button and the home button (on the front) at the same time. If that doesn't work 2) try plugging it into a different charger than you normally use. If that works, you need a new charger. If it doesn't show that it's charging within 30 seconds, your iPad charging port or battery probably has a problem and will need repaired.
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
My iPad 3 battery is charging slowly how do I speed it up?
Make sure you are using an authentic charger if that doesn't help update your ipsw to the latest firmware
1helpful
2answers
How do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
1helpful
2answers
The Ipad battery: how many hours a day can you use Ipad without the battery acting up after a month. I do not have a computer Ipad is it. the batter seems to be low even after being charged up 100...
The iPad 3 is not yet available, yet thousands of designs for cases and covers have already been made for this new apple product. Decide what colour you want your ipad 3 cases to have, and what design. This is not all! Not at all! Due to the many hot apple iPad 3 accessories available you will also be able to choose the material out of which your accessory will be made. Anything from wood to titanium. Maybe an interesting plastic? Flexible rubber? Or maybe aluminium? What will it be?
3answers
2helpful
3answers
Apple Ipad won't charge
the ipad will charge with the charger that comes with it
if you want to charge it with the cpu you have to turn off the ipod before it will charge
Press and hold sleep /wake button
til it says slide to power off
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
