It is possible that your camera's internal computer might be going out. I had similar symptoms on one of my cameras. Have the batteries ever died in the camera? It could be one of the causes.
The cost to have the new computer installed on my camera, was about $230.00. I took mine to the local professional computer repair shop and it was returned to me in less than 24 hours and working great. Your price will vary with the make, model of your camera. Mine was a Canon 5D mk2. Take it there and let them give you the diagnosis and then decide if it's worth it to repair or replace it. Don't use my fee as your guide, unless you have the same camera.
Hope this helps. Mike
SOURCE: In Review mode, why is a blue or black screen displayed instead of a picture?
The picture has no thumbnail or is an unrecognized format. Transfer the picture to the computer or delete the picture.
SOURCE: Kodak EasyShare P850 - Black screen
I have fixed several Kodak models including this one with exactly the same problem. Sometimes tapping on the side will fix it temporally. The fix is to open the back of the camera and snap the connector from the lens. If the camer is dropped the connector can come unsnapped. You should only attempt this if you have had some experence working on electronics. Be careful inside the camera especially in the upper right corner which is where the high voltage is for the flash. You can get a large shock from this camera if your not careful.
SOURCE: Kodak easyshare DX 7630 screen black in take a picture mode but is fine in review etc
Hey Wistra,
You could try resetting your camera to the factory settings by choosing the reset to default setting in the menu. If this doesn't work the sensor on the camera is most likely broken, and you should have the camera looked at by an authorized service technician. If the camera was purchased less than a year ago the repair would most likely be covered under manufacturers’ warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: LCD/EVF screen come on but is "snowy"
The problem is the lens is not opening, If you look into the lens you can see it is closed. This will require a trip to the repair shop.
SOURCE: The picture-taking display is unclear and pinkish
Check if this is in all the SCN.
If this is on the printed pics also or just on the LCD.
If this is an intermittedly problem if there is a pattern in the occurance.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
