Question about LG WM2301H Washer
My LG WM2301h won't drain. I have tried cleaning the hose but either did not clean it or that is not the problem?
My LG WM2301h wont drain. I tried cleaning out the hose and some water went through but not very much. I still got the OE error. When I open the drain hose at the bottom front the water drains out. When the pump turns on it drains faster from there. The pump is making noise. Is there a way to check the pump or the hose to see if either is working at 100% or not? Any other things I should check?
    Scholar:
    New Friend:
  • 187 Answers
I can almost certainly tell you that Your Pump is gone! There is no way to check them because the symptom you describe is the check! The pumps go for $35 to $135. So shop around and get ready to take your entire machine apart. Good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Posted on Dec 13, 2015
  • Paul Marquard
    Paul Marquard Dec 13, 2015
    Thank you Steven, I have ordered a new pump. I have replaced the hose so I should be able to take it apart again.
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Sometimes small objects find their way through the drain filter drawer into the pump impeller and impede its operation, that could be the noise that you are hearing, alternatively the bearings of the pump are worn in which case you would need to replace it.
Posted on Feb 10, 2016
    New Friend:
  • 14 Answers
Hello I 'll help you out just follow these instructions
Oe error code is due to water drain time out
To check and know for sure what's the problem :
1- set program to rinse and let the washing machine finished filling water .
2 . Press power button to turn it off.
3. Set program to spin and start it
You should hear the pump giving a sound for few seconds and water starts going out from the drain hose .
If you here the sound and no water or poor draining
( not full capacity coming out from hose )
Then the drain pump is damaged even if it's working but actually the fan is spinning left and right not in a steady single direction to drain water out .
Before changing pump be sure to check the
Hose from tub to drain pump filter not clogged by
Foreign stuff like a sock or a napkin .
The pump is cheap any standard 25 or 30 watts
Pump works better to be ascoll brand for durability.
Regards
Posted on Feb 04, 2016
6ya staff
SOURCE:
Anonymous
  • 185 Answers
SOURCE: LG WM1812CW Does not Drain
check the timer
Posted on Mar 26, 2008
Anonymous
SOURCE: LG WM2233H* Clogged drain
After draining and cleaning filter, reset washer--Unplug unit and hold Start (selector) button for 10 seconds. Plug unit in and restart.
Posted on Nov 16, 2008
Anonymous
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
Paul
  • 381 Answers
SOURCE: LG Tromm Washer flashing OE. drained from the
Take the front off and check all the hoses going in and out of the drain pump.
Posted on Dec 15, 2009
Norm Dickerson
  • 291 Answers
SOURCE: how to clean pump filter on lg wm2688hwm
No, probably have a bad water pump, very common for this washer. I would pull the washer out, lean it against your wall, brace or block it up so you can crawl under it. You will see where the drain hose comes out of the bottom left of the drum and enters the drain filter. Remove the hoses and check for debris or clothes in the hoses or where the drum outlet is. If no restrictions then replace your water pump. Good Luck, Appliance Specialists
Posted on Dec 20, 2009
Lg wm2301h keeps saying oe
problem with water not draining..kindly check drain motor..
Feb 05, 2014 | LG WM2301H Washer
Water is leaking out
Plastic housing broken, dispenser to bowl hose fractured. Soap powder has hardened in dispencer hose blocking same, needs cleaning out.
Dec 20, 2013 | LG WM2301H Washer
Wont drain
4902682_300.jpgopen small box in front unscrew water will come out from there after that clean inside there is a fan u might find some coins socks pants scales that might help
Oct 25, 2012 | LG WM2301H Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
Oct 11, 2012 | Washing Machines
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
LG WM2301H
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Sep 03, 2012 | LG Washing Machines
Water won't drain and it says oe
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
THe machine won't rinse. Displaying a "OE" symbol
Kevin
Jul 26, 2011 | LG Washing Machines
It won't drain away water.
take drain hose put in pail at ground level if it drains trouble with pump
if no drain try
put a hose in drain pipe hose force water back into machine then see if it drains the plumbing of machine has to cleaned spin tub shall have to be remove to clean
Jun 12, 2011 | Washing Machines
LG WM2277HW. How to clean out the hose drain. Ive tried useing a coat hanger but no luck. what else can I use to clean it out. It wont drain the water. Thanks for your time
TAKE A SHOP VAC, PUT THE HOSE ON THE VAC ON THE EXHAUST SIDE, TAPE IT TO THE HOSE YOU WANT TO CLEAN OUT AND TURN ON THE VAC-WILL BLOW THE DUST BUNNIES AND VARMITS RIGHT OUT
Aug 06, 2009 | Washing Machines
LG WM2301H Washer Logo
555 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
