Saflok MT Electronic Hotel / Motel Lock | Existing Installs Before April, 2011 Logo
k
khiffa Posted on Dec 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i fix my locks,when you insert a key card all three lights i.e. green, orange, red will blink
I work at a hotel
Kaye Day
Level 3:
  • Master 744 Answers
  • Posted on Dec 02, 2015
 Kaye Day
Master
Level 3:
Answers
744
Questions
Helped
222987
Points
13385
You should be trained at the hotel by management so they can keep track with what you still need to learn.
Eric Albanese
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 02, 2016
Eric Albanese
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2127
Points
Fatal test mode. Replace PCB board or use a starter deck to go back to factory mode.
2answers
Alternating green and orange three times; no jammed paper
make model manual
whatever this machine is?
'make model (what it is)' as the first three words in every question please. :>D
2answers
Ving card lock question: door is locked, program room key to unlock door. Doesn't work, light is RED. Master key/staff key works, Light GREEN. Why does the master key open door while room key doesn't?
www.elock2u.net/wp-content/uploads/2016/04/Hotel-Lock-System-Manual.pdf
If lock latch part is engaged, You can unlock it by using emergency key in ... Cards are programmed to function cards ... *1 When Hotel lock system is finished with all room settings, issue Setting cards ..... The most important card in system, the Master card can access all .... Then the lock will not work for its current Guest card.
Key card lock to my hotel door will blink green then red and not unlock the door when i put the key card in. What is the problem/
The green blink is it registering the card. Good news is you are putting it in the correct way. The red means the card is either not for that room (double check your room number) or has lost its encoding. Likely if you booked an extra unexpected day or the card came close to something magnetic erasing the data.
Easy fix is to go to the front desk with your I.D. or name and room number and they will fix the card for you.
Cannot turn TV on.Cyles red and green continuosly
I know if its a sony they have internal fuses that can be changed in order to get the display to work again. Check out this forum on sony's site it explains what the lights symbolize and how to fix the condition...
https://us.en.kb.sony.com/app/answers/detail/a_id/32192/~/red,-green-or-orange-lights-are-on-or-blinking-on-the-tv.
3answers
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
50px1d-uc When I try to turn it on, the red power light blinks, I hear a click, then the light turns amber then back to red. Usually I'd hear the click then it would turn green and the tv would work...
I came across this in a manual
-Without CableCARDTM : Illuminates red in
standby mode, Illuminates green when the
TV is turned on.
-Inserting the CableCARDTM : Illuminates
orange in standby mode, Illuminates green
when the TV is turned on....
You might want to check your cable card. It seems to mimic your problem. Try taking the card out and gently clean, with a dry cloth, the contacts/strip. Then take some "canned air" and blow out the card socket from the side to dislodge any accumulated debris.
2answers
I have 5 brand new TESA Onity locks that will not work after I program the lock.Just blinks red when I insert the key in it.
This page is for Onity's Supplies and Services:
http://www.onity.com/support/supplies-and-services/
It is the only source of contact information that I could find toward solving your problem.
I suggest that you contact them through the phone number listed on this page. For your convenience,
By Phone: 1-800-749-2983
By Email: [email protected]
2helpful
2answers
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Ipad is not working
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
2answers
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Top Saflok Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Saflok Lock and Locksmithing Expert? Answer questions, earn points and help others
