Error code
542 error comes when a problem in heater .1:terrmistors dirty or defect.must check and clean that .2:termostats maybe cut .check that.if that is cut no change because that is expensive.must cool that for along time in freezer .(about 120minutes)usually that rapier by this .4:check your heater lamp.5:check heater control board.
RESET; press c key (usually yello key)--inter107 by numeral keys--press and hold stop key(usually red key)for3 second .then off power key and on .
Problem mostly in fixing unit from SC 542 to 548 something check thermostat thermistor clean then .reset c 1 07 stop press hold goto sp 7 datalog to reset SC jam error history
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
