Is this a fire hazard?
I showed you what it means before. Did you follow the links?
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced http://products.geappliances.com/appliance/gea-support-search-content?contentId=16238
F0
Function key stuck
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
http://www.appliancepartspros.com/repair-help/dacor-fault-codes.html
