The Direct TV remote which is paired with the Sharp TV would not turn on or off the TV so tried the Sharp remote and that had same problem. I can turn on and off the TV with the set side button on the TV but the remote will not respond to any buttons.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Testimonial: "Steve, Many thanks for the suggestion. I tried the recommended steps and it worked! I didn't think to simply unplug the unit and plug it back in but that did the trick. Simple yet effective (but overlooked). Thanks so much for your advice. Awesome! Tom"
