Question about Iomega Prestige Desktop 500 GB USB 20 Hard Drive
Where can I get my hard drive mended it just ticking and will not work
  • 3,267 Answers
I've had a pretty good success rate with freezing drives to recover data from a dying/dead drive. Much simpler and cheaper then most other methods of data recovery.
Freezing the drive shrinks everything inside, sometimes freeing up stuck/seized/trapped components, or keeping an overheating component from shutting the drive down right away.
Stick the drive in a ziplock bag(to seal out moisture) in the freezer.
While it's freezing, set everything up to quickly transfer your files off the drive if it does work. After a couple hours in the freezer, plug the drive in and see what it does. It may only work for a few minutes, for hours, or weeks. Pull your data off as fast as you can, if it stops again, re-freeze it and start where you left off. I've frozen drives 3-4 times to get everything off.
Posted on Dec 04, 2015
6ya staff
SOURCE:
Simpletech external hard drive not workin on windows 7
Windows 7 seems to have a lot of issues with external hard drives and any usb attached devices
Click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
the next works on usb data / pen drives im not sure on external hard drives
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
and i have found that leaving the a usb data drive plugged in and restarting my computer W7 my usb drive will work again (strange)
whatever works
hope it helps
Nov 05, 2012 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
Hard drive won't read
can you see the drive ? if yes
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Feb 24, 2012 | Maxtor One Touch II (EO1E200) 200 GB Hard...
My hard disk turn off every 1 hour then it make a unusal sound nd wont restart again . Then again next day its start and after 1 hour it gets hang nd start making tick tick noise ... does m hard disk...
Go to the power settings and set it to never turn off hard drive...the tick tick noise are the read and write heads working (that's what writes information on the hard drive) which is perfectly normal with an older hard drive....the hang is probably a virus or needs a good cleaning...I recommend advanced system care as a program to clean your hard drive and fix the errors....uninstall any and all programs not needed or unused
Sep 15, 2011 | Computers & Internet
My trascend hard drive -25 -320gb suddenly started to ask for format - i have around 160gb data in this drive how to get it back or make hard drive work again
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive hope it helps
Aug 12, 2011 | GTech G-Tech G-Drive Combo 500GB...
My flash when enter in computer show message format and after format also not work
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this
hope this helps you
Jul 10, 2011 | Kingston Technologies 512MB DataTraveler I...
Drive sounds like tick tick and not mounting
Hi, If you have warranty remaining then you can definately replace it but if not then you'll have to search for some Hard disk repair stores & there u can ask for the data backup too.
Regards
kunal
Jul 14, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Will not connect to computer
If it's ticking, it's likely damaged. I know some hard drives have a high failure rate, and can die early.
Jun 08, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
Skype working
I mended it somehow after going to control panel and looking at the volume control etc ticked something and since talked to my nephew in germany thank you
Oct 20, 2008 | Sony VAIO VGN-N130G/W Notebook
Laptop usb hard disk
I've had this problem many times with external SATA hard drive plugged into the usb. My 120gig hard drive takes significant power to operate it. On laptops with a long cable to the usb, I get the Tick tick tick sound and the light flash in concert with the ticking. On laptops with short cables to the usb, the hard drive works. On one desk top, the hard drive doesn't work on the front usb but does on the rear because the rear has no cables. The usb comes off the motherboard. Conclusion? Most likely a voltage problem from longer than usual cables from the motherboard to the usb. One solution is plug the hard drive in the rear usb. Another solution is buy a more expensive cable linking the hard drive to the usb. Or buy a shorter cable. More expensive cable may have thicker wires that won't resist the current. But I do not believe for a minute that the hard drive is faulty. I've seen it too many times and it has never been a faulty hard drive.
Sep 15, 2007 | Western Digital 320GB MyBook External USB...
Iomega Prestige Desktop 500 GB USB 20 Hard Drive Logo
133 people viewed this question
Top Iomega Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
 Grubhead
Grubhead
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
