SOURCE: My screen is showning flickering white lights
Hi, To confirm that indeed you laptop CPU is working normally, you can try plugging an external monitor. This will also verify that your onboard video or memory is not the issue. Assuming you have tried the above, as to the screen flashing, it can probably be the LCD panel display. It can either be the video converter or your backlight inverter (or CCF fluorescent tube). Any of the two would require opening the display panel and component level repair. Should you not be comfortable cracking the display open and circuit analysis/diagnosis, you may need the services of a qualified professional. Hope this give you an idea and work out for you. Good luck and post again how things turn up or if you need further information. Kind regards.
Hi, you need to do a factory reset!
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the volume + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
let me know how you get on!
SOURCE: rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
That symbol means that the tablet battery is plugged in and is supposed to be receiving charging voltage. If the battery is bad, it may not charge but the tablet will still work with the charger plugged in.
