Most modern machines are cold fill only and only have one inlet at the back in which case the answer to your question is yes. If you have 2 water inlets at the back and if they both need to be connected, you can get a "Y" piece that you fit to the cold water outlet with one end and connect the other 2 parts of the "Y" to the hot and cold inlets. You can also blank off the hot water inlet if you need to and then connect the cold only as normal.
