According to the manufacturer, the reset procedure is documented here and on page 42 of the instruction manual:
http://faq.yamaha.com/us/en/article/musical-instruments/keyboards/digitalkeyboards/portable_keyboards/psr500/656/2085/psr500-psr500m_factory_reset_procedure
SOURCE: i need for :yamaha keeboard psr 9000 :danish manual
hej I asked my lokal store. thank ouy for answer. best regards poulc
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
SOURCE: Hi My yamaha PSR S500
Check that your adapter is a 12VDC with a current rating of at least 1 amp (1000ma) AND that the center pin of the connector is the POSITIVE.
SOURCE: What's your problem?how can i connect my mic in YAMAHA PSR s710
I believe you must have a USB audio mic. If you do, plug it into the USB port in the back of the unit;
SOURCE: my Yamaha PSR S750 do not light up every thing is silence
No power is reaching the unit or PS is defective.
While holding the uppermost white key, turn power on. Resets to default settings. This procedure also applies to the DGX-300, DGX-230, YPG-235, DGX-205, DGX-203, PSR-295, PSR-293, DGX-505, DGX-305, DGX-620, DGX-520, YPG-525, YPG-625, DGX-530, YPG-535, DGX-650, DGX-640
