2000 Pontiac Montana Logo
Posted on Jul 14, 2009
No power windows door locks interior lights or key chimes
All the fuses are good and there is power to them
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
768
Points
Try checking the pin switches in the door jambs if you have no power to these items with the door open i would lean toward the pin switches being stuck or bad ground or broken not an uncommon problem
Im trying to locate and remove the ignition chime on 2005 nissan sentra any tips on the easiest and quickest way possible
Your best bet , take it to a qualified repair shop .
SMART ENTRANCE CONTROL UNIT PFP:28596 Description EKS003A2 OUTLINE The smart entrance control unit totally controls the following body electrical system operations. ? Warning chime ? Rear window defogger and door mirror defogger ? Power door locks ? Remote keyless entry system ? Vehicle security system ? Interior lamp ? Battery saver control BATTERY SAVER CONTROL Interior Lamp/Map Lamp/Vanity Lamps The lamps turn off automatically when the interior lamp, map lamp or/and vanity lamps are illuminated with the ignition key in the OFF position, if the lamp remains lit by the door switch open signal or if the lamp switch is in the ON position for approximately 10 minutes. After lamps are turned off by the battery saver system, the lamps illuminate again when: ? Driver's door is locked or unlocked, ? Door is opened or closed, ? Key is inserted into or removed from the ignition key cylinder. Rear Window Defogger/Door Mirror Defogger Rear window defogger and door mirror defogger are turned off approximately 15 minutes after the rear window defogger switch is turned on. INPUT/OUTPUT
Warning chime Key switch (Insert) Ignition switch (ON) Lighting switch (1st or 2nd) Seat belt buckle switch LH Front door switch LH Warning chime (located in smart entrance control unit)
Nothing for you to remove ! Without a factory scan tool U can do nothing .
TIME CONTROL UNIT PFP:28491 Description (Without Power Door Locks) EKS003A6 OUTLINE The time control unit totally controls the following body electrical system operations. ? Warning chime ? Rear window defogger INPUT/OUTPUT System Input Output Warning chime Key switch (Insert) Ignition switch (ON) Lighting switch (1st or 2nd) Seat belt buckle switch LH Front door switch LH Warning chime (located in time control unit) Rear window defogger Ignition switch (ON) Rear window defogger switch Rear window defogger relay
Where is the chime located on 2005 nissan sentra
Does it have power locks ?
2helpful
Open door chimes and keys left in in car chimes plus left on chimes not working question what operates chimes door lock ?
Door left open chime is operated by your interior light switch. It is located in a few places on different vehicles. Often in the door jam at the front or low down on the pillar at the rear of the door. You will notice a little black rubber boot and when you push it it goes in and out. That is your interior light switch.
2helpful
3answers
The interior lights in my 2000 Ford F250 will not turn off. How can I get the lights to turn off?
Just to get the interior lights off to save your battery, you could pull the fuse. Refer to the service manual to determine the proper fuse.
To fix the problem, i would suspect one of the door switches is faulty.
3helpful
2answers
Electric windwows, door locks, alarm, interior lights not working
Sounds like you may have a bad ground clean battery terminals!! get wiring schematic!!!! Good Luck!!!!
1helpful
Door chime and courtesy light (under side mirror)
     You have broken wires in the flexable harness between the door and the body. Pull the rubber boot back to inspect.
2helpful
1997 venture keyless remote programming
SYSTEM OPERATION
System warning lamp located on top of the instrument panel
Press UNLOCK button once , turns on interior lamps and deactivates alarm (if fitted)
Press UNLOCK button twice w/in 5 seconds unlocks all doors, turns on interior lamp and deactivates alarm (if fitted)
To activate alarm system (if fitted):
Switch ignition OFF
Open driver's door
Press Lock button on remote
Close Driver door
warning lamp will flash when system is activated
Press remote power sliding door button will open sliding door (if fitted) only if unlocked first
Pressing remote panic button:
*Sounds horn intermittently
*Flashes exterior lamps
*Turns on interior lamps
**Pressing panic for the second time OR switching ignition ON deactivates alarm.
PROGRAMMING
Remobe key from ignition switch
Remove the "BCM PRGRM" fuse, from the fuse box
Close all doors
Turn ignition switch to the ACC position
With in 1 SECOND , turn the ignition switch to OFF then back to 'ACC'
(really, with in one second)
Open and close the driver's door. A chime will sound, indicating programming mode activated
Press and HOLD LOCK and UNLOCK SIMULTANEOUSLY untill a chime sounds 2 times ( about 15 seconds)
Repeat this exact procedure for all remotes to be programmed
Remove key from ignition
Refit 'BCM PRGRM' fuse.
4 REMOTES MAXIMUM CAN BE PROGRAMMED
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
