Have you tried replacing the fuse in the plug top? Please make sure you replace with the correct rated fuse, too big and you can destroy your dryer, too small and it just wont work.
You will need to replace the orface the one for the LP is smaller and won't let enough gas out. LP has a lot more presure. Best to take your model # to an appliance parts store and get the right one.
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
