I cant get my palomar to transmit. When I bid at on the ebay auction it was a listed as a 225 with blue face but arrived with a black 250 faceplate but no ELITE or HD on it so I was confused. It is a smaller square type box and I figured it Has to be a low drive but not positive. Lights on amp work except for the L M H light. When I key up I hear click like its transmitting but no light goes on but pre amp light goes off.. when I key up I hear a Clik like transmitting but maybe SSB delay?. I have a Astatic 600 meter hooked up and it shows noting when amp is turned on . Not even a SWR reading will appear when amps turned on but when Its turned off all 3 meters work fine. I have been putting in 1 or 2 watts and swing to 12 or so but no signal. I have tried a 4 watt dead key still nothing. I talk skip barefoot with the radio alone all the time. I am not a dummy( wife thinks I am) but maybe something I am missing. Maybe a Ground issue or what? All wires big gauge and straight to battery.. I am lost at this point.. I am running both from the same battery as I always have with little amps. Brand new hi end strong battery as well. Let me know if you can Help.. Thanks M K
There is your problem . You bought it on ebay ,paid twice as much as it is actually worth and you got screwed . Now you have to get it fixed because you bought a broken piece of equipment. If you have another radio hook it up to the amp and see if it works . Maybe the amp don't like your radio? If it doesn't work then we know its the amp so now treat it like another radio and look inside to see if anything is out of place or maybe burnt , from ebay . You might need a multi meter to do this . check all your voltages and make sure the amp has continuity going from pl to pl set your meter to ohms and insert the probes into the hole on each pl . that will tell you if there is contact . Now you should get a schematic to check out all the voltages of the components inside . It just might be that the amp is drawing to much or not enough amps to run it . I am confident you will find the problem and get it fixed .
SOURCE: modulation
have you happened to check the cable to your antennas? maybe you got a cut in the insulation. thats the only idea i can come up with being that you have had all the work done to it and still havin problems.
SOURCE: runin a 700 watt amp drive w/super star radio 2watts in
There are a couple of reasons this could be happening #1 and the most probable one is that your watt meter only reads RMS instead of PEP or #2 you are over driving your amp.Try to find a friend that has a watt meter that reads PEP and try that if that does'nt work turn down your drive some.Good Luck Dan
SOURCE: cobra 2000 with a d 104 mic and a palomor tx100 bi
I have several linear/amps/kickers and my best is the Demco Demon 500 Plus that swings 1500 watts on the A.M. side. NEVER KEY UP MORE THAN 2 WATTS!!! Now to your fix:take your radio to a tec and have him install what they call a "swing kit". Tell him you want the lowest deadkey possible with the highest swing. The lower the deadkey, gets you more audio and you will have the maximum output. Always turn the RF Power all the way down (if equiped). You will need a "swing kit" installed for best performance!
Take your linear with you and have him tune it on all setting (high, med, low...etc..,). You do NOT have to have them matched if he does his job right.
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB SERVICE!!!
