If your JUKI HZL-DX7 sewing machine's automatic thread cutter is leaving behind a short piece of thread in the mechanism after each cut, there might be a few potential causes for this issue. Here are some steps you can take to troubleshoot and address the problem:
Thread Tension: Check the tension settings for both the upper and lower threads. Improper tension can cause thread to be left behind in the thread cutter mechanism. Make sure the tension is balanced and appropriate for the type of fabric you're sewing.
Thread Quality: Poor-quality or thick threads can sometimes get caught in the thread cutter mechanism. Ensure you're using good-quality threads that are suitable for your sewing project.
Thread Path and Thread Guides: Make sure the upper and lower threads are properly threaded through the machine's threading path and guides. Improper threading can lead to thread buildup in the cutter area.
Thread Cutter Mechanism Cleaning: The thread cutter mechanism might have accumulated lint, debris, or bits of thread over time. Gently clean the thread cutter area with a small brush, compressed air, or a vacuum cleaner to remove any buildup.
Blade Inspection: Check the blade of the thread cutter for any nicks, dullness, or damage. A damaged blade might not cut the thread cleanly, leaving behind remnants.
Thread Cutter Mechanism Lubrication: Some sewing machines have small moving parts in the thread cutter area that benefit from occasional lubrication. Consult your sewing machine's manual to see if lubrication is recommended and use a sewing machine-safe lubricant if needed.
Machine Maintenance: Regular maintenance of your sewing machine, including cleaning and oiling as recommended in the manual, can help prevent issues with the thread cutter mechanism.
Consult the Manual: Refer to your JUKI HZL-DX7 sewing machine's manual for specific instructions on troubleshooting and maintaining the automatic thread cutter.
Professional Service: If the issue persists after trying these steps, it might be best to seek the assistance of a professional sewing machine technician. They can diagnose and repair any mechanical issues with the thread cutter mechanism.
Remember that working with sewing machines involves mechanical parts and electrical components, so it's important to follow safety guidelines and, if needed, seek professional assistance to avoid causing further damage or harm.
If your Juki HZL-210 Excite's automatic thread cutter is cutting your thread when you're trying to straight stitch, there are a few things you can check:
Make sure you're using the correct presser foot: If the wrong presser foot is installed, it can activate the automatic thread cutter when you don't want it to. Ensure that you're using the appropriate presser foot for your straight stitch.
Check your thread tension: An incorrect thread tension can also cause the automatic thread cutter to activate at the wrong time. Make sure your thread tension is properly set for the type of fabric you're using and the type of stitch you want to make.
Clean the machine: Accumulated lint or debris can cause the automatic thread cutter to malfunction. Use a brush or compressed air to clean the machine, particularly around the thread cutter mechanism.
Reset the machine: Turn off the machine and unplug it for a few minutes, then plug it back in and turn it on again. This can sometimes reset the automatic thread cutter and resolve any issues.
If none of these solutions work, you may need to take your machine to a professional for servicing or repair.
Parts for Tanaka Trimmers & Brush Cutters - Repairtoolparts has a wide range of Tanaka Trimmers & Brush Cutters Parts at ... Buy Tanaka TBC-500 repair parts online to fix your tool. ... Figure#: 1-55 COIL,IGNITION Part Number: 6695934.
I used to use a Ryobi 2.5 hp and it worked fine but if you are concerned go higher hp. It's probably more important that the router is a variable speed model. The bigger the size of cutter required for raised panel doors the more torque and revs are produced. You need to ensure starting on slowest speed and adjust up to speed required. Speed should be based on size of cutter and to me is set by sound( a nice hum, not screaming) and vibration( NO VIBRATION)! The cut needs to be done in several passes, maintaining constant feed speed,( don't burn your expensive cutter) allowing cutter and machine to do work maintaining the hum and no vibration. And of course set your guards etc!! If this is on going work for you perhaps look into a spindle moulder with attachment to take router cutters
Are they horizontal lines or vertical lines??
however you can follow the below steps
1. unplug the power chord from the back of the printer without turning the printer off... then press and hold the power button for 30 sec... then release the button... then plug in the power chord chord back to the printer.. check if it is making a copy or not..
then clean the rollers with a lint free cloth.. however the lint free cloth should e moistened with water... then clean it properly...
then do a reset on the printer..
Press BL/TL/BL/BL Buttons, in sequence. (BL: Bottom Left , TL: Top Left)
Touch Support Menu.
Press Right arrow for Reset Menu and Touch OK.
Press Right arrow for Semi-Full Reset and Touch OK.
Wait for unit to Power Down/Turn Off.
Press Power button to turn the Printer On.
THEN CHECK IF IT WORKS OR NOT...
Then try making a blank copy and check... If its still the same then service the product..
The 128LD is a detachable shaft machine, there are a number of attachments, hedge trimmer, brush cutter, brush, blower etc, there is a alloy clamp at the bottom of the machines tube, just push the attachment tube into the clamp, there is a locating hole so as you know it is fully home, now screw the clamping screw fully down to lock in place
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
