SOURCE: what is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
SOURCE: I have a 1976 75 hp 2 stroke evinrude that is overheating.
In the bottom of the engine is a rubber impeller/water pump. It is in the housing above the prop, not hard to change. Basic tools a six pack and about an hour. The part will cost you about $20, and you can order it from NAPA parts store. They will be about 50% less than a boat shop. Good Luck
SOURCE: oil to petrol for 5.litre can
the fuel to gas ratio should be 50;1 50 parts oil to 1 part fuel
SOURCE: wiring diagram
If theres wires coming out of the motor it is more than likely an electric motor , If it is a gasoline engine it is a 4 stroke engine
SOURCE: oil weight to use for 1989 evinrude 2 stroke 90 hp
The oil is mixed with the gas, just buy 2 cycle engine oil and follow ratio mixture
