Televison & Video Logo
S
Susan Longinette Posted on Dec 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Howw do I get rid of the panel that runs across the bottom of the screen describing the features without the remote? Dolby, sleep timer, backlight contrast, HDMI, eco
Jeff Bird
Level 3:
  • Master 1,348 Answers
  • Posted on Dec 11, 2015
Jeff Bird
Master
Level 3:
Answers
1348
Questions
0
Helped
363454
Points
4615
Hi without a remote u can't press exit button ?? Try leaving power turned on & switch power of at the wall for 5 or ten minutes it might lose its memory. God luck.
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
Haier 32" flat panel LE32N1620 can not get rid of box across top of screen
hi have you tried pressing info button on the remote or the tv symbol on the remote
regards
shaun
1helpful
Does it have a sleep timer?
hello!
yes, it has the one! you need to go to the menu, setup portion of that. you'll see: clock set, timers, etc. That's where you will find it. A bit complicated, but possible. If your remote lacks "sleep" button, get the one with it.
good luck,
Alex.
1helpful
14MG135 4:3 14" Television 14 in. Is this a
No this is not a digital tv. You will need a converter box/set top box. I am posting the specifications. Where it says tuner it would have to say atsc and/or qam for it to be a digital television
Product description Product Identifiers Brand Thomson Model 14MG135 MPN 14MG135
Key Features Screen Size 14"
Technical Features Screen Type Non-Flat Screen Aspect Ratio 4:3 Built-in Tuner NTSC, PAL, SECAM Adjustable Color Temperature Without Adjustable Color Temperature
Connectivity Front Input Connectors Audio (RCA) x 1, Composite x 1 Rear Input Connectors RF x 1
Audio Features Number Of Speakers 1 Speaker Power 1 x 3.5 Watt Audio Type Mono Subwoofer Without Subwoofer Audio Leveler Without Audio Leveler
Miscellaneous OSD Languages Danish, Dutch, English, Finnish, French, German, Greek, Italian, Portuguese, Russian, Slovakian, Spanish, Swedish, Turkish Parental Control Proprietary Sleep Timer With Sleep Timer Remote Control Standard Additional Features Headphone Jack
2helpful
2answers
When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
4helpful
My remote does not have the sleep timer button.
Open cover on the bottom part of the remote SLEEP button is there.
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
2helpful
What power rated speaker shoud I use with my str-d865
Sony STRD865 Home Receiver - Dolby Pro Logic - 1995 Related Models << STRD665 ($300) | STRD965 ($400) >> Here's the specs, see below but looks like 100Wx2 speakers at 8ohms. Features: A/V remote; Digital Signal Processing w/ 6 soundfields (Dolby Surround, Hall, Theater, Stadium, Game, Acoustic), Soundfield link; 30 presets; 4 audio/ 4 video inputs (1 tape monitor); sleep timer Specs: Stereo: 100w x2 into 8 ohms (20-20k Hz) at 0.3% THD; Pro Logic: 100w x3; Surround: 25w x2; subwoofer preout; FM sens. 11.2 dBf; 17" W x 5 3/4" H x 14 1/2" D Hope this helps!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
