SOURCE: Admin Password
The master password for the Toshiba e-Studio 45 (using controller gl-1010) is 349845. Use a web browser to open the printer's built-in web access: TopAccess, and click the log-in link on the right hand side to use this password.
SOURCE: I have a Toshiba studio 281c, we forgot the ADMIN password, help!
the default password should be "123456".
If u did changed the default password, then u need to enter setting mode 08 - 263 to check or edit the password.
SOURCE: I need a way to reset admin password back to
Enter settings mode 08-263, enter your desire password (within 10 digits).Default password is "123456"
SOURCE: I lost the admin password to my 282 copier. How do
The hard drive stores the operating system for this machine so you would have to have the copier programming to reload after you changed the hard drive and I am not certain that the programming would even support a larger drive. Default code is 123456 Turn off copier, press 0 and 8 and hold down while turning copier on. enter 263, start, enter new code press enter. Turn off and on
SOURCE: How do you reset Admin on a Toshiba e-studio 162D
In the manual it says to "Turn on power while holding down the status button on the network expansion kit. Continue to hold down the status button until a beep sounds."
It looks like the default password was TOSHIBA which took me forever to find. The user name should just be admin.
