Question about Toshiba 32AV502R LCD TV
My remote do not work to turn on television
I have to manual turn on tv the control is good
    Top Expert:
  • Toshiba Master
  • 76,171 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=F8oYoZslgbs
Posted on Dec 12, 2015
6ya staff
SOURCE:
LCD TV DELL 2600 remote does not work until tv is turn on, also tv is very hard to turn on with manual button.
hi,hard to push bottons on TV manual controls usually happens because they are not use for a long time carbon accumulates inside the switches.You can just use a contact cleaner spray (windex) just spay it directly to the button and press repeatedly until dry..good luck1
Apr 07, 2012 | Dell W2600 26 in. LCD Television
Television was switched off with remote control, now remote is not working, how do I restart the telly
If TV is manually turn off, the remote may not work. Have to manually start the TV then urn off with remote to turn on with remote. You might also change the batteries in remote(within ten minutes of removing b batteries to save the codes in universal remotes).
Nov 21, 2010 | Televison & Video
The TV is frozen on one channel manual buttons not working nor re
hello here is how to reset your tv. turn on the tv while holding the reset button on the remote control,press the power button on the tv (the tv will turn itself off, then back on again) release the reset button. if this don't work get back to me and we'll try some think else good luck
regards
shaun
Jul 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Cannot turn on or off the tv with remote,can't turn up or down vo
It sounds like either the remote is no good or the ir receiver in the TV has gone bad. try new batteries, or even a universal remote. this will help tell you if it's the TV or remote, good luck
May 31, 2010 | LG 42LG50 42 in. LCD HDTV
Good remote control doesnt work in the tv
IF you haven't replaced the batteries it may just be the age of the remote although in good condition to the eyes, maybe you should consider getting a universal remote, it comes with a manual and a list of codes and instructions on how to program it on your TV.
Feb 27, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
LG42PC3D TV - No remote control. Manual control works.
dont blame the receiver yet, the problem mostly comes from the remote control. it may be the infrared emiting problem. checkout if the infrared in the remote control is emited well. to see this infrared you can read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
Dec 05, 2009 | LG 42PC3D 42 in. Plasma Television
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
Oct 27, 2009 | Olevia 227-S11 27 in. LCD TV
RCA tv and a zenith remote cl015
take a poop ans sculpt it into a new remote.
Oh, i would let it dry out in the sun for a couple days before attempting to sculpt, up to you.
Dec 01, 2007 | Radio Shack 3-in-1 Easy-to-Use Universal...
My manual tv controls don't work on the tv or cablr remote
Had the same issue 4 1/2 months after purchase(2 weeks after Wal Mart's warranty expired of course). I contacted Ilo and was told it was the main circuit board.
Aug 11, 2007 | iLO 3200 32 in. LCD Television
Remote won't turn on tv
no, there is no fuse on the television that control the remote, there is a component that they call IF means infrared.its a circuit that recieved the signal from the remote,amplify them and convert them to signals then decoded by the system control.if the remote is not working with the two tv then the IF circuit needs to be repaired.since you say that the remote works with the direct tv box.then i could assume that the remote is working.it could also be that the remote is not compatible with the tvs.try getting the the right remotes for the tv and see what happens.if it does not turn the tv on then we safely say it is the IF circuit.then you will have to take your set to a repair tech for repairs.good luck.
Mar 19, 2007 | Sanyo AVM-3259S TV
Toshiba 32AV502R LCD TV Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
