Question about Sansui HDLCD3210 32 in. LCD TV
What is pg blocked - Sansui HDLCD3210 32 in. LCD TV
    Habit-Forming:
  • 132 Answers
sounds like a Parental Guidance lockout, check the settings on the TV preferences menu and turn off Parental Controls, you will need the TV Handset
Posted on Jan 21, 2016
6ya staff
SOURCE:
How to unblock my sony xav-65 (Video Blocked For Your Safety) Video Blocked For Your Safety And How To Unblock
You cant. The unit blocks the video while the vehicle is in motion. This is a safety feature - see pg 16 of the manual.
Apr 25, 2015 | Sony XAV65 Video Receiver with Double DIN...
I have CL 52 and want assumed to MX310. shows the codeu 059. whether it will be possible to submit the cartridge CL 52 in MX 310? How to do it ?
Below is the list of cartridges the MX310 accepts:
Black: 219 pages (PG-37), 329 pages (PG-40), 510 pages (PG-50), Colour: 207 pages (CL-
38), 312 pages (CL-41), 545 pages (CL-51) [2]
Black: 1785 photos (PG-37), 2760 photos (PG-40), 5310 photos
(PG-50), Colour: 85 photos (CL-38), 126 photos (CL-41), 204 photos (CL-51) [3]
No other cartridges fit. srri
May 30, 2011 | Office Equipment & Supplies
42 inch flat screen shows v-chip block tv-14 lsv what does that mean? tv fades tremendously turns blue then shuts off
V-chip Block
TV- 14 - this is a rating for movies and TV programs. Basically means PG-13 like the old movie theater rating.
lsv- means, language, ***, violence.
You TV can be set to block these programs.
In you menu look for a catagory called "locks" or "ratings"
there you will find the options of what can be veiwed and what will be blocked.
if you everything to be available, just disable all settings.
if you want to choose different things to be allowed, just click on the icons and they become blocked.
Apr 12, 2011 | Olevia LT42HVi 42 in. LCD Television
What Ink Cartridge That I Have To Use? Is It The Canon 830 PG-830 Black Or The Canon 810 Black PG-810 My Model Is Canon Inkjet iP1800 series
I Believe you can use both, The 810 is the low capacity version and the 830 is the high capacity.
Hope this helps Regards GM
Apr 10, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
{TAB} after I scan barcodes??
I just had to do this today... took me a while, but I figured it out. Download the manual from here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Scan the following barcodes in order and it will add a tab to the end of the barcode you scan.
Scan "Scan Options" Pg 13-6
Scan "<Data><Suffix>" Pg 13-7
Scan "Scan Suffix>" Pg 13-5
Scan "7" Pg Appendix D-3
Scan "0" Pg Appendix D-1
Scan "9" Pg Appendix D-4
Scan "Enter" Pg 13-8
You should now have a tab at the end of any barcodes you scan. Hope this helps!
Mar 03, 2010 | Symbol LS2208 Handheld
Removing parent block on a used Toshiba 36HF73 36
If you don't have the unlock code you can do this to remove it. Please take a few moments to rate my answer..Thank you...
If you cannot remember your PIN code
While the PIN code entering screen is displayed, press RECALL
four times within five seconds. The PIN code will be released
(Blocking Reset status restored)
Nov 17, 2009 | Toshiba 36HF73 36" TV
Printer not recognizing pg-50 cartridge
I had exactly the same problem. I called the Canon helpdesk and apparently the PG-50 is not compatible with the MP210. I then bought a new PG-40 which works fine.
Bit annoying as I have wasted £35 or so on the PG-50. This is also a bit misleading from Canon as the PG-50 fits into the MP210 perfectly, and when you are looking at it on the shelf it looks like a long-life version of the PG-40.
But there doesn't seem to be any way around it that I have found. Just bite the bullet, write it off to experience and buy a new PG-40.
Apr 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How do we block a certain channel?
You will need to call our technical support line on 0845 20 20 118. Click Here for help
Dec 24, 2008 | Sharp LC52SB55U LCD TV
Message protected program by tv-pg
Go into Menu /V Chip arrow key up to tv rating should show all locked volume down or visversa should should view all Note may have to volume up to get to options from menu depending on how old the tv is.
Apr 04, 2007 | Emerson EWV403 VHS VCR
Sansui HDLCD3210 32 in. LCD TV Logo
329 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
