I received a power outage to my house and my LG Refridge LFX25960TT is making a clicking noise with the LED lights on the ICE/Water dispenser flashing. There is no power to the internal Fridge storage
The error code dH on your LG refrigerator is indicating a water supply problem. This could be caused by a few different issues:
Clogged or frozen water line: The water line supplying the icemaker and water dispenser may be clogged or frozen. This can prevent water from flowing to the icemaker and dispenser. Check the water line and make sure that it is not clogged or frozen.
Water inlet valve: The water inlet valve that supplies water to the ice maker and dispenser may be faulty or clogged. This can prevent water from flowing to the icemaker and dispenser. You can check the water inlet valve and make sure it is functioning properly or if it is clogged.
Water filter: A clogged water filter can prevent water from flowing to the icemaker and dispenser. If your refrigerator has a water filter, make sure that it is not clogged and has been replaced recently.
Water pressure: If the water pressure is too low, it can prevent water from flowing to the icemaker and dispenser. Make sure that the water pressure in your refrigerator is adequate.
You should first try to check the water line, water inlet valve, water filter, and water pressure. If none of these solutions work, please contact a professional technician or LG customer service to diagnose and fix the problem.
Check the line that goes from the water pipe to the back of the refrig. Someone may have used something they shouldn't have. The lines in the refrig won't break down like that.
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
It is behind the ice bucket, remove ice bucket and you will see it there, however, it is a continuous run type motor so the best way
to defrost it is to run it by depressing the ice dispenser lever until you free it up after removing the ice bucket, it may take up to 5 minutes to thaw it out
More than likely the user interface board that controls that portion of the machine is probably bad, or, worse case scenario the main control board which has the overall say so for the machine has gone out which isn't uncommon either. My best advice is if your going to do it yourself buy your parts from www.repairclinic.com because of their return policy which you can return any part you bought even if installed/
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150.
We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
