Question about LG Washing Machines
LG tromm washer is stuck at 22 minutes and just keeps washing and spinning
The washing cycle is stuck at 25%. Keeps washing and then spining and repeats
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Sometimes the firmware or program in the microcontroller of the machine gets scrambled due to electrical spikes or fluorescent lamp frequencies in the vicinity of the machine.
Unplug the mains supply for about 10 to 20 minutes and retry, this will normally solve the problem as the firmware program resets itself.
Posted on Mar 11, 2016
6ya staff
SOURCE:
Anonymous
  • 10 Answers
SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Posted on Feb 12, 2008
johnychel
isaac johny
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
Anonymous
  • 373 Answers
SOURCE: vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 13, 2008
Anonymous
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
Greg Mills
  • 497 Answers
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Posted on Sep 15, 2009
I have an lg tromm front load washer. I am getting the IE fault. I have cleaned the inlet screens and drain filter. It gets stuck at the 13 min mark, seems like it just won't go to spin cycle.
LE code mean suds have built up. Using non he (High Efficiency) detergent or too much detergent will cause this error most front loaders use he detergent only there is a he swirl on the container
Let your washer sit idle or 45 minutes.Unplg washer as well
Plug in and turn on as left spin speed select no spin press Start/pause to start a drain only cycle. When cycle is complete remove load. Start a rinse•spin cycle to clean out residue.
If the sud were too much you may have to repeat
Jul 25, 2015 | LG Washing Machines
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
Washer wont drain lg tromm frontloading washer
You need to isolate the drain pump and check the voltage at the time of the drain cycle. If no voltage is present then you need to check on the control board as it can be a failure of the drive.
If voltage is present but there is no drain action then the valve pump is stuck, choked or faulty.
remove and check: click on : Drain.
Feb 27, 2013 | LG WM2016C
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$).  So far they have determined it is not the motor or either of the control boards.  We think it might be a relay switch or possibly the brake.  Good luck with yours, we just went out and bought a new washer.
Jun 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Feb 12, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
949 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
