Tablets & eReaders Logo
Mary Marsh Posted on Dec 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant download anything to my kindle it want connect to my Bluetooth I'm getting so frustrated plz help me. I have reset to factory twice
Jim Dowell
Level 3:
Master:
  • Master 345 Answers
  • Posted on Dec 14, 2015
Jim Dowell
Master
Level 3:
Master:
Answers
345
Questions
0
Helped
121306
Points
1057
A kindle doesn't use bluetooth, it uses WiFi. They are two different things. In order to use WiFi you need a wireless router. If you are having trouble connecting to a wireless router make sure you enter the password in your kindle in the correct case since the passwords are case sensitive.
Kindle is running slow. How to fix?
If your Kindle is running slow, here are a few things you can try to fix it:
  1. Restart your Kindle: This is one of the easiest and most effective ways to fix any performance issues. Simply press and hold the power button for 20 seconds until the device turns off, then turn it back on.
  2. Remove any unnecessary content: If you have too much content on your Kindle, it can slow down the device. Remove any books or files that you don't need.
  3. Clear cache and data: Clearing the cache and data can help to speed up your Kindle. To do this, go to "Settings" > "Storage" > "Cached Data" and tap on "Clear Cached Data."
  4. Update the software: Make sure that your Kindle is running the latest software version. To check for updates, go to "Settings" > "Device Options" > "System Updates."
  5. Disable Wi-Fi and Bluetooth: If you're not using Wi-Fi or Bluetooth, turning them off can help to improve performance.
  6. Reset your Kindle to factory settings: If none of the above solutions work, you can try resetting your Kindle to factory settings. To do this, go to "Settings" > "Device Options" > "Reset to Factory Defaults."
Keep in mind that some older Kindle models may experience performance issues due to hardware limitations. In that case, upgrading to a newer model might be the best solution.
2answers
Fire tablet I can not get into setting with out password forgot it Have done the 5x enter word but not luck
Starting with the Kindle Fire off, press and hold "Volume Down" and "Power" simultaneously. The Amazon system recovery screen should appear. Use the volume buttons to toggle the selection to "wipe data/factory reset". Press the "Power" button to choose the selection.
How to Soft & Hard Reset Kindle Fire - Technipages
https://www.technipages.com > soft-hard-reset-kindle-fire
Please note you will lose all data on tablet. But you will get a working tablet back.
Hi,i had to factory restore my kindle hdx 8.9 2th gen.i can not locate any bookmarks.tryed it twice no luck,any help
You may need to install updates since you factory reset and it is an older tablet. Check and see if there are updates available.
Why did my kindle reset on its on
Amazon.com: Customer Discussions: Kindle Fire reset itself to ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Mar 1, 2013 - I turned it off & the next morning I turned it on and it had reset itself back to factory setting!!!! Did I loss everything? My games, downloads ... Kindle Fire HD reset itself to ...
Oct 8, 2015
Sep 2, 2013
Kindle Paperwhite auto rebooting
Oct 21, 2012
Kindle Touch keeps restarting it ...
Dec 22, 2011
More results from www.amazon.com
Surviving A Kindle Fire Factory Reset - With Most Of Your ...
2answers
When screen opens it suddenly starts asking for a password. I have never used a password, don't have one and cannot unlock my Kindle Fire HD
Give enter to password, in blank, withoul inputting anything. Maybe it accepts it as password.
The other possiblity is that you've been pranked and someone defined a password
Here you have a tutorial for Password Remove:
Kindle Fire Password Remove
If you can't get the password, you should do a Factory Reset.
Here you have some video tutorials how to do
Kindle Fire HD How to Reset Back to Factory Settings
Kindle Fire HD how to reset when locked up EpicReviewsTech CC
How to Factory Reset Amazon Kindle Fire Tablet Tutorial
1helpful
2answers
I'm having problems with my Kindle I can't get it to do anything. It keeps saying The process android.process.media has stopped. (Press ok) then it says download manager has stopped. It keeps going ba
Chances are you will need to do a factory reset on the unit. This mean reinstalling all your apps again. I have also seen issues with having the auto update turned on. I would suggest turning this off and updating apps manually. Here is a list of factory resets for all different kindle models. Good Luck.
Where is reset button in a kindle
Hold down the 'on' switch for 20 seconds. The Kindle will reboot - you will not lose anything on your Kindle.
If you need to reset it to factory default (which will remove ALL content) then:
  1. From Home, press the Menu button, and then select Settings.
  2. In Settings, press the Menu button again, and then select Reset to Factory Defaults. Your device will power off and power back on.
2answers
Amazon kindle suport web page
If I understand you correctly, you have a new Kindle Fire HD and would like to transfer the data from your old Kindle Fire to your new Kindle Fire HD. This is easy, follow these steps:
Step 1: Connect the old Kindle to Wireless. Pull down the upper status bar, select More + and then select My Account on the old Kindle
Step 2: Using the Old Kindle, select Deregister under My Account, let the task complete
Step 3: When the old Kindle has Deregistered, then pickup the new Kindle. If you accidentally registered this Kindle Deregister it and then Factory Reset the device.
Step 4: Now the old Kindle is Deregistered and the new Kindle is factory Fresh, let's begin the process.
Step 5: On the new Kindle, let's reboot after Factory Resetting the device. When the device powers back up you should be presented with a login Window. Go ahead and register the device to the same account as the Old Kindle. The sync process should begin automaticlly, it can take up to one full day to sync all your content.
1helpful
5answers
I have a store demo 8.9 kindle fire hd. How do i get wipe it and/or root so i can use it as a regular tablet
The Demo Kindle Fire Model Number 3HT7G is completely locked down. It is not possible to remove the Demo, reset the Kindle or Flash new Firmware using a Backup and Restore Utility like Kindle Fire First Aide. The Development Team of Kindle Fire First Aide is working on a procedure to reset these Kindles but the procedure will involve opening the Kindle which Voids the Warranty. Until we develop this procedure you are locked out. Sorry, I wish I had better news. Best regards, Chris Bryant - Prokennexusa at XDA Developers
Cant get WiFi conection keeps asking for password cannot remember it
Try resetting the router back to factory default, and set up again with a new password. What make and model of router are you using? Just ran into this issue with neighbors 2 new Kindles, which connect fine to my NetGear router, but will not connect to their Linksys WRT54GS router.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
