Televison & Video Logo
A
Anonymous Posted on Dec 15, 2015
Volume keeps going down to zero
Turn tv on, manually turn up volume and the volume will slowly turn itself down to zero
GAK.
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 5 Answers
  • Posted on Feb 02, 2022
GAK.
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
5
Questions
0
Helped
6531
Points
18
I took a second TV and connected roku red and white audio plugs to it and connected yellow video plug to TV with bad volume control now both are controlled with the roku remote. The 44 inch TV had the bad volume so video is on it and audio is on 15 inch.
Claude Kayser
Level 3:
Top Expert:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Emerson Master 9,098 Answers
  • Posted on Dec 15, 2015
Claude Kayser
Emerson Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067381
Points
28436
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
1helpful
Help! My Toshiba 26avs02u TVs volume turns itself down to zero when i try to turn it up. How do i fix this problem?
If volume bar is presented continuously, the TV is in a continuous command volume down state. Could be volume down button down stuck on TV, or possibly remote, or some other device capable of emulating a remote is issuing command volume down. Or control logic in TV has failed with this unusual result.
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Techwood tv volume going back down
I've got this problem these fixing only work for a sort time! Volume just turns itself down?! Anyone no the real fix?
2answers
Samsung lcd 32 inches screen. The volume turns down to zero by itself. The remote control looses control. Control through remote control keeps coming and going intermittently.volume can be turned up...
Try removing the batteries from the remote after you set the volume, just to determine if the remote is causing the problem or not. I have seen stuff spilled on remotes and they just go crazy.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
1helpful
3answers
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
2answers
Volume keeps going down by itself. I'll use the remote to turn it back up and it goes back down to zero again.
It's rare but happens. Sometimes the volume button (or rather the plastic piece that activates the button when pressed) can get stuck. That or there has been a cleaning chemical leak down onto the button on the board itself and corroded it, causing a constant short.
As for the second Q, I feel that your TV may have received a shock through the audio line and the audio amplifier may have taken the hit. These problem can lead into multiple bad compontnts, such as a bad SMD IC on the bottom of the board.
1helpful
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
11helpful
5answers
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
