Tablets & eReaders Logo
Debbie Colby-Tripp Posted on Dec 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I fix the broken screen on my RCA tablet and now my Wi-Fi won't work.
Claude Kayser
Level 3:
Top Expert:
  • Tablets & eR... Master 9,098 Answers
  • Posted on Dec 15, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061551
Points
28436
Droid Pro: wifi won't turn on - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Motorola Droid Pro
Dec 17, 2012 - 25 posts - ‎23 authors
Ok so I tried to turn on my WiFi in the settings and it would say turning on ... myphone, done a factory reset and even used a WiFi fixing app. ... wifi fixer doesn'twork. ... to lock my phone without the screen staying on for 15 seconds or so. ... I was having trouble turning on wifi on my tablet and one of the post ... Auto Rotate does not work.
May 11, 2014
New Tablet/Authentication Problem with Wifi
Dec 17, 2013
WiFi stuck "turning on"
Aug 18, 2013
More results from forums.androidcentral.com
Android Tablets Forum - Tom's Guide
5 Related Answers
Azrael SRL
  • 11800 Answers
  • Posted on May 24, 2010
SOURCE: wireless internet access
A wireless 802.11b LAN adapter is included in you tablet, activate it thru Control Panel / Wireless. Unfortunately this is the first generation standard and as such is extremely slow, has very limited range and is no longer supported by a lot of the newer generation devices/hotpoints.
Anonymous
  • 4 Answers
  • Posted on Aug 03, 2011
SOURCE: When I go to use
Do not expose the <a href="http://www.laptopsbatterysupplier.com/4200mah-replacement-laptop-battery-for-a1280-p-2055.html?cPath=9_2163">apple A1280 battery</a> to high heat or freezing temperatures. Do not leave your <a href="http://www.laptopsbatterysupplier.com/4600mah-replacement-laptop-battery-for-a1281-p-2061.html?cPath=9_2202">apple A1281 battery</a>in your car in the summer. Hot <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps8-c-32_2062.html">Sony BPS8 battery</a> discharge very quickly, and cold ones can't create as much power. 6. Fully charge new <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps9-c-32_2063.html">Sony BPS9 battery</a> packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity. 7. For laptops that work as Desktop Replacement, the <a href="http://www.laptopsbatterysupplier.com/toshiba-laptop-battery-pa3534u1bas-c-447_1843.html">Toshiba PA3534U-1BAS battery</a> should be re -installed every 3-4 weeks and allowed to fully discharge. 8. Leaving the <a href=" http://www.laptopsbatterysupplier.com/4400mah-replacement-laptop-battery-for-gateway-nv52-p-1904.html?cPath=35_2094">Gateway Nv52 battery</a> in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Aug 10, 2011
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
Anonymous
  • 343 Answers
  • Posted on Aug 16, 2011
SOURCE: hi i have a pandigital novel book tablet
Please go to the Pandigital website and update the firmware, I will attach a link below.
Thanks for using FixYa
http://www.pandigital.net/Downloads
Anonymous
  • Posted on Apr 06, 2012
SOURCE: how can I connect my tablet to wi-fi
on your settings go to wi fi settings turn it on
After factory reset my rca 7" tablet, RCT6077W2, stops at dogs screen
Hi Koleta, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
What happens when my tablet won't even turn on?
Hi Mike, The link below is a youtube video showing you how to fix your tablet....CHEERS..
Unable to get internet
You can separate the troubleshooting into parts. Go to a place having a wi-fi internet hot-spot, like Starbucks or Gloria Jeans'. Assuming you are in the USA:
http://www.wififreespot.com/
Get a coffee and turn your tablet wi-fi on. From
http://www.manualslib.com/manual/742236/Rca-Rct6272w23.html?page=11#manual
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it. Tap 'Agree to conditions' if necessary.
You should then be able to go to a webpage. Once you get this bit working, you can turn to your home internet.
You need of course an account with an ISP, who will probably supply you with a gateway (modem/router). If you only have a modem (connection box to the ISP) that does not have a wi-fi capability, you will need to get a router (wi-fi broadcaster). These can be quite small and neat.
http://phandroid.s3.amazonaws.com/wp-content/uploads/2015/10/OnHub-by-ASUS-Screen-Shot-2015-10-27-at-5.29.02-PM.png
For assistance on this contact your ISP tech help line, since some of the advice is peculiar to the equipment they use.
Connect the router (if you needed to get one) to the modem with an ethernet cable
http://cdn2.pcadvisor.co.uk/cmsdata/features/3502678/ethernet-cable.jpg
and follow the setup instructions that came with it. Then do the same as in the cafe wi-fi hot spot. It should work.
I got. A RCA Android detachable keyboard it won't type
I had one and had to tap where I wanted to type then the keyboard worked but the touch screen keyboard was also there. It was a little annoying though
Why wont my tablet connect to the wi-fi
Have you opened settings and entered your WI FI password /key: ,if you have not you will not be allowed connection . hope this helps.
2answers
How do I set password on Wi-Fi orca android tablet
Answer Line: Change your Wi-Fi password on various ...
www.pcworld.com/.../change-your-wi-fi-password-on-various-...
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
How to Connect Your Android Tablet to a Wi-Fi Network ...
www.dummies.com/.../how-to-connect-your-android-tablet-to-a-wifi-net...
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
How do i change my wifi password [Solved] - WiFi - Cell Phone ...
1helpful
2answers
USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
Try a factory reset of your tablet first. Here is a link to the procedure:
http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
How Would I know if my tablet was broken?
hi not op.. but searching for help. Battery @ 100% and touch screen buttons not recognizing touch... This tablet belongs to my disabled 7 yr. old HELP
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
