SOURCE: Loud humming noise from subwoofer
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
SOURCE: Speaker makes a rather loud humming noise.
You can go buy a audioquest SUB-X subwoofer cable with a additional ground wire on it an connect the ground cable to the ground slot of the receiver an the other end to a screw on the sub or into one of the high output terminals on the woofer if it has them an this will take that humming sound right away but the cable is around $90
SOURCE: making loud humming noise only.but if you plug
If I understand this correctly: with NO input or cable attached it hums; with an RCA cable attached it works. (What does 'some' mean in this regard?)
You say that connecting the RCA cable improves its sound. That tells me you're supplying a ground through the RCA cable for stray voltage in the sub.
It seems there may be a basic power issue if it hums with no input. Sometimes a given power source in a home may be wired differently than others or may insufficient grounding, which can result in hum. Try reversing the sub's power plug or move it somewhere else.
Since the sub contains its own electronics it is also susceptible to strong external magnetic fields. Keep it and any signal cables leading to it some distance away from other electrical devices like TV's.
SOURCE: I have a pair of
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
