There are no capacitors or components to replace in this repair. Locate a flat shiny square box (location (TM801S). This is the transformer that illuminates your TV Screen. Next, find leg connection EYA4, turn the board over and find a poor solder connection there. Clean the dried rosin core solder flux (looks like syrup). Scrape an area next to this pin (green paint on board) to expose some copper (next to pin). You will add solder to this and connect to create a good ground. May as well do EYA5, as this looks like a possible problem. Install power supply and your TV will come back to life. Thanks for asking, Matt of Martins TV Repair.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
SOURCE: LN-T4061F Goes black after a couple of minutes.
The T-Con bd is probably going bad. Also the Main bd could be bad. Have a trained samsung tech troubleshoot the set.
SOURCE: Will not power on or off with remote or on
This model have a common problem, it on and off cycles, and you can hear the turn on sound repeat. It is the main board failure, you can replace it, the part # you can see a sticker on the board, the format is like BN99-99999C. cost approx $120.
SOURCE: Samsung LCD HD TV Model
Th clicking is from the power relay. You will have to open it up, the first place to look will be the power supply module, look to see if it has any bad caps with leaking/bulging tops first, caps can look OK but can be bad due to high ESR.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: My Samsung LCD TV la40r81bd wont switch on. I
If you want to DIY this TV you need to open the back cover of your TV 9BE SURE TO UNPLUG THE UNIT BEFORE SERVICING) Examine first the power supply section.using a voltage tester measure the output of it.
5v for the CPU board
12v for the sound amplifier
24 v for the inverter board/backlight.
if one of this voltage is missing then you need to repair first the power supply.measure first this voltages and post a message for further assistance.
