Question about Tablets & eReaders
Wht if tablet does not turn off after u hold the power button
    Top Expert:
  • Tablets & eR... Master
  • 9,098 Answers
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - android wont turn on. You turn on your Android phone or tablet by pressing its power button - simple. If that button won't work, your device isn't necessarily broken ... often see an "empty battery" indicator on the screen when you try to turn it on. ... You should only have to hold the Power button down for ten ...
samsung tablet wont turn on - Samsung - Android Tablets - Tom's Guide
www.tomsguide.com/forum/id-2155281/samsung-tablet-wont-turn.html
3 days ago - 43 posts - ‎36 authors
Posted on Dec 16, 2015
2 Suggested Answers
6ya staff
SOURCE:
cougar123
John Sweeney
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
My tablet wont go pass go
works on most android tablets
some have reset hole with a button press that
if not turn off tablet
hold power button and volume down button till you see menu then reset
or hold power button and volume up button till you see menu then do factory reset. this erases everything on tablet
Jul 10, 2015 | Tablets & eReaders
I forgot my password to my Chromo Tablet & I need to know how to reset the password.
Check to see if there is a Reset button on your tablet. Usually it will be next to Power or Volume buttons. Use a small Pin to insert, press, and HOLD it for 15 seconds. Your tablet should reboot. See if it will reset your tablet and let you log into your tablet.
If that does not work, press and hold Power button until your tablet turns off completely. Press and hold Volume Down + Power at the same time for 15-20 seconds. See if the Recovery menu will comes up.
If still not working, power off again. Press and hold Volume Up + Power buttons for 15-20 seconds.
Feb 22, 2015 | Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Tablet will turn on but not load all the way need help
Hi, for any tablet turn it off by pressing holding the power button. Then press and hold the volume down button and press the power button. then select reset using the volume button. then the tablet would be reset to the default settings. then you are good to go. cheers. bye. get back to me for further answers.
Nov 17, 2014 | Nextbook Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
New m760 kocaso tablet has no sound
There are two buttons next to the power on button, they control the volume. Try turning the volume up key.
Here is the manual. Support Manuals
Jul 27, 2014 | Kocaso M760 WHT Android 4.0 ICS 7"...
How do i unfreeze my tablet
Hold down power button until shuts off. If freezing continues then has a virus. Go to app store and download avast and do a full system scan. If can't do that then do a factory reset. Back up everything on computer first. Hold down home button, power button and volume down at the same time when powered off. After boot screen release only the power button. When a screen loads use volume keys to navigate to factory restore and press power button then wait till done. If volume down doesn't work then use volume up instead.
Jul 24, 2014 | Visual Land ME-107-8GB-WHT Tablet Computer...
Computer not turning on
please be more descriptive. The make of the tablet, what exactly lead to the issue,
you may try by leaving the tablet charge overnight but ensure that the charger is working before doing that. If the tablet haves center button you can try to press and hold the power button and keep tapping the center button for about 15 times. It might turn on if no center button try holding power and keep tapping power down. When you are up to it, you may even try the combination with power up button as I don't know the model.
let know if it worked
Mar 25, 2014 | Tablets & eReaders
Tablets & eReaders Logo
523 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
