1. It obviously has to have a digital tuner fitted and I assume it has.
2. You perhaps are not following the correct procedure for setting up the TV to scan the spectrum and lock in the channels one by one. There should be an automatic station tuning feature for the TV which you set up and let run as will be explained in the user guide/manual.
3. There is a possible problem with your antenna or antenna connections but if you had no problems with a previous TV picking up digital channels it will not be the antenna.
Which model Westinghouse TV do you have?
Read the user manual
check that you have the correct antenna for your area
talk with the technicians where you bought the unit
contact the manufacturer on a contact them phone number and discuss the problem with their technicians
