The jumping action when the motor speed is high is normal.when it is jumping abnormally,there may be problem with the supports that is springs and dampers attached with the barrel.the springs and dampers are attached at all the four sides to control barrel vibration or oscillation.check it.if it is good,comment below .i will recommend you another tip.
http://goo.gl/o1eCQz
