However, 2 indicators light at the same time (ie Wash, then Rinse, then Spin, then Wash Rinse). Is this correct operation? Should 2 indicators light up at the same time or should each indicator light up individually? This happens whether I rotate clockwise or counterclockwise.
Bruce:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
SOURCE: F51 & F72 Codes
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Whirlpool Cabrio Washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button.
Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board.
