I am trying to figure out how to remove the tensioner assembly. I require a Torx T50 but there isn't enough to even get the bit into the bolt.
Images for 2008 Nissan Versa Removing tensioner
how do you remove tension off surpentine belt tensioner - Nissan Forum
www.nissanforums.com/.../151350-how-do-you-remove-tension-off.htm...
Feb 20, 2009 - 4 posts - 2 authors
2008+ Nissan Rogue ... QR25 2.5L Engine Engine Discussion: 2002+ Sentra SE-R and SpecV ... how do you remove tension off surpentine belt tensioner ... changed these before, but which way do you turn the tensioner, how ...
Replacing the Water Pump on a '04-'08 Maxima *DIY*
1 post
Aug 31, 2011
Belt noise: replace idler pulley? - GA16DE
Sep 16, 2008
Step by step instructions -Upper Timing Chain Tensioner
Dec 8, 2007
Idler Pulley Bearing Replacement Info
May 16, 2003
More results from www.nissanforums.com
Nissan Versa Tensioner Pulley Issue (1/1) - EricTheCarGuy ...
www.ericthecarguy.com/.../50669-nissan-versa-tensioner-pulley-issue
Nissan Versa Tensioner Pulley Issue 1 year 7 months ago #94552 ... for a 50 Torx to be used to remove the entire tensioner pulley assembly but all of my 50Trx
How to Replace serpentine belt 2008 Nissan Altima ...
? 11:29
https://www.youtube.com/watch?v=5NchA85pnAE
Jul 2, 2014 - Uploaded by nivekoch
How to Replace serpentine belt 2008 Nissan Altima In this video i'll be going ... 2005 Nissan Altima 2.5L serpentine belt tensionerreplacement ...
Testimonial: "Thank you for the response. I've actually checked these out previously but nothing actually explaining the how to. I have the T50 bit needed but there is absolutely no room to even get the bit in there. I read that you can remove the motor mount above the belts and lift with a jack just enough for clearance but i wanted additional verification on that before wanting to proceed with it."
Required tools:
13mm open end wrench 10mm shallow and deep socket 8mm socket long flathead screwdriver 17mm deep socket T50 torx socket 1/4", 3/8ths and 1/2" ratchets and extensions E10 inverted torx sockets 6mm Allen wrench 15mm open end wrench 7mm socket 12mm open end wrench 14mm socket 12mm socket 8mm, 9mm and 10mm Allen head sockets 19mm socket pry bar needle nose pliers
If you are doing this because your timing belt broke you will also need to buy a complete cylinder head, head gasket set, and both idler pulleys. ALL DAEWOO MODELS WILL BREAK THE INTAKE AND EXHAUST VALVES WHEN THE TIMING BELT BREAKS.
Start by removing the air cleaner assembly from the throttle body, remove the air filter and housing jack up the vehicle and remove the wheel, remove the plastic shielding in front of the accessory drive belt assembly, remove the accessory drive belt, place a jack with a block of wood on top underneath the engine oil pan remove the front engine mount, remove the crank shaft pulley ( the 4 Allen head bolts only not the 17mm bolt in the center.) remove the metal plate behind the engine mount bracket on the engine, remove the plastic timing belt cover 3 clips on top 2 10mm bolts on bottom. Rotate the engine until the #1 cyl. is at Top Dead Center on the compression stroke or line up the crankshaft timing mark with the mark on the inner timing belt cover ( notch in cover with notch in pulley) on the camshaft pulleys -- ( intake cam line up the line on the pulley with the line on the inner cover)( exhaust cam line up the arrow on the pulley with the arrow on the inner cover) loosen the 13mm bolt in the belt tensioner and using the Allen wrench rotate the tab until there is slack in the belt. Remove the belt. At this time I would recommend you replace the water pump, both plastic idler pulleys as they tend to overheat and lockup, and the belt tensioner. Make sure all your marks are lined up, you may need a helper to hold the Exhaust Cam in place as it tends to move during belt installation. Put the timing belt underneath the crankshaft pulley, install the belt leaving the intake cam for last and NO BELT SLACK on the right side between the crank and the exhaust cam. Once the belt is installed rotate the crankshaft over 2 revolutions and make sure is rotates freely, and your timing marks are aligned perfectly if not the engine will not run properly, tension the belt as needed. Installation is the same as removal.
Required tools:
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
